Subaru Impreza R205
Subaru Impreza R205
hjjemee
Subaru Impreza R205Major equipment of Subaru Impreza R205
Mechanism:
STI tuned inverted strut and coil springs for front suspension
STI tuned damper and coil springs for rear suspension
"Brembo" 6-pot brake caliper with STI silver logo and 18-inch grooved
rotors for front brake
"Brembo" 4-pot brake caliper with STI silver logo and 18-inch grooved
rotors for rear brake
STI designed 18-inch cast aluminum wheels
Bridgestone specially designed "POTENZA RE070" (245/40R18) tyres
STI designed flexible type front strut tower bar
STI designed flexible type lower arm stiffener of front suspension
R205 ECU (Engine Control Unit)
R205 exhaust pipe
R205 twin scroll turbocharger with flexible type ball bearings for the
turbine axle bearing
R205 sport muffler with lowered back pressure exhaust
R205 front stabilizer
Interior:
R205 side sill plate
R205 serial number plate
Exterior:
R205 front grille (black)
STI designed front under spoiler
STI designed side STI garnish (black metallic)
STI designed rear under spoiler
STI designed rear spoiler (black)
R205 badges on front grille and rear gate
Others:
The planed production is limited to 400 units
Major specifications:
Engine type; Horizontally-Opposed 4-cylinder DOHC 16-valve turbocharged engine
Displacement; 1,994 cc
Transmission; 6 speed manual transmission
Maximum output; 235kW (320PS)/6,400 rpm
Maximum torque; 431Nm (44.0kg.m)/4,000 rpm
Pls bring yr family to experience our hospitality.You may submit for loan
application prior to booking.
Credit Card/ Cash/ Cheques are welcome..
azman @ hjjemee
0127433911
[email protected]
rgds
* local A.P
* ready stock
* low interest rate
* islamic loan
* 1st come 1st served
