Stainless Steel Braided Hose
kenzo
6,000 RPM
Mentari, Sunway
- Stainless Steel Braided Able to Withstand High Pressure and Heat
- There is TWO type of Inner Layer to chose from which is Teflon and Synthetic-Nitrile
- Can be use for Fuel Lines, wastegate vacuum, ATF, coolant hose, oil cooler
- Comes in various size for AN-4, AN-6, AN-8, AN-10
- Able to just replace ur OEM hose :biggrin:
- Able to connect with the AN fittings which i also sell here http://http://www.zerotohundred.com/newforums/engine-and-performance/322634-aluminum-anodised-fittings-an-4-an-6-an-8-an-10-a.html#post4120223
Price Per Feet =
AN-4 - RM20
AN-6 - RM25
AN-8 - RM30
AN-10 - RM35
WEBSITE
http://www.overboost-motorsports.com
Join Us On Facebook HERE!
CLICK HERE FOR CONTACT FORM
CONTACT DETAILS
E-Mail - [email protected]
Mobile - +6014-932 1108 / +6017-694 8087 / +6010-377 5401 / +6012-955 1800
MSN - [email protected]
YM - [email protected]
Location Sunway or Courier RM10
Terms & Conditions
1) Items are all BRAND NEW and in excellent condition. Unless stated otherwise.
2) Purchase at your own risk. Items sold are non-refundable, non-returnable and non-exchangeable.
3) We are not liable for any damage(s) caused to or by the products(s) after shipment.
4) Please make sure the product(s) you purchase fits/suites the make/model of choice of vehicle. However i will try my best to get info for you.
5) For COD please make sure the products(s) that you are about to purchase are in good condition.
6) We do not provide installation but i can guide you or recommend you a workshop.
Thank You
bro, how i do the connector in between fuel regulator and the adapter, if i dun wan use bracket. i need the 8mm for replace my fuel hose.
hi bro,
i also like to know how to do the connection before purchase.
connection with the AN fittings is it? remove the nut at the AN fitting, slide in the hose deeply, and screw in back, make sure its tight so the liquid,oil,water,air wont leak :biggrin:
u can also just use this hose and connect, inside it is just a hose :biggrin:
and its cover with stainless steel braided to prevent leak from high pressure bro
depends on the car also bro, most ppl use 6mm, some ppl use 10mm, wat car u driving bro? :biggrin:
let me go back n measure...
the size is same like the one we connect to the sard FPR.
any idea?
Many2 more stuff for sale, kindly contact me at 014-6691572 or 016-9644963 ( KENZO ), or email me at [email protected] or add me on msn at [email protected]
50 meters will be coming in soon! hot stuff! plug and play with ur original hose without the AN connectors, also able to use with the AN connecters :biggrin:
