Sony Car Audio System Promotion
ICE -In Car Entertainment
MyYong
XS-GTX 1620S Sony Component Sets
RM 365!!!!!!
16cm 2-Way Separate Speaker
- Peak Power 260W
- Rated Input Power 60W
- Frequency Response 40Hz - 22kHz
- Sensitivity 88 +- 2db /W/m
Woofer
- HOP Cone
- Ferrite Magnet
- Rubber Surround
Tweeter
- 23mm TETRON Dome
- 19.5mm Neodymium Magnet
HOP
Greater linearity, smoother response, and far better sound.
Crossover
A device that splits sound into various frequency bands, for more accurate sound reproduction through frequency dependant components.
Max Input Power
The maximum amount of power a speaker can handle
By the way, NOW, WITH EVERY PURCHASE 1 SET OF SONY COMPONENT SETS, YOU CAN GET A FREE EXTREME DYNAMAT WOTH RM150!!!!
GET IT WHILE STOCK LAST!!!
XM- ZR604 Sony 4/3 Channel Stereo Power Amplifier
RM 599!!!!!!
This filter cut out the mid-range and high tones, delivering only the low frequency’s signals to your woofers.
* MOSFET Power Supply
* Maximum Output Power: 4 Ch x 110W at 4ohm
* Maximum Output Power: 2 Ch x 150W at 2ohm + 1 Ch x 300W at 4ohm
* Rated Output Power: 4 Ch x 60W at 4 ohm(1.0% THD)
* Rated Output Power: 4 Ch x 130W at 4 ohm (0.1% THD)
* Rated Output Power: 3 Ch x 130W at 4 ohm (0.1% THD)
* Rated Output Power: 4 Ch x 65W at 2 ohm (0.1% THD)
* Low Pass Filter (Rear): 80Hz, -18dB/oct
* Frequency Response: 5Hz-50kHz
* Signal-to-Noise Ratio: 97dB
* Dimensions ( W x H x D in mm): 396 x 55 x 256
Amplifier
Channel Configuration 4/3
Low Pass Filter (Selectable)/Slope 80Hz/-18dB/oct
Signal to Noise Ratio (Rated Output) 97dB
Total Harmonic Distortion (1kHz) < 0.005%
Input: Number of Channels 4
Toroidal Transfomer Yes
Line In: Input Sensitivity (V) 0.3-6
Load Capability: 2 ohm Yes
Current Drain (Rated Output Power at 4 ohm) 33A (at 4 ohm)
Weight Approx. 3.1kg
XS-L120P5A Sony Woofer
30cm high perfomance enclosure-tpe subwoofer
Speaker Size (inch): 12
Peak Power (W): 1000
Rated Power (RMS, W): 300
Impedance (ohms): 4
Price :RM 258!!!!!
XS-GTF1625B 6.5" Coaxial 2 way
Peak Power: 190W
Rated Input Power: 40W
Frequency Response: 35Hz – 25kHz
Sensitivity: 90dB/W/m
Woofer: HOP Cone
Woofer: Ferrite Magnet
Woofer: Rubber Coated Cloth Surround Edge
Mid-Range: 35mm HDLD (High Density Layered Diaphragm)
Mid-Range: 15mm Neodymium Magnet
Mid-Range: Balanced Dome
Price :RM 168!!!!!
XS-GTF6935B 6X9 Coaxial 3 way
Peak Power: 300W
Rated Input Power: 60W
Frequency Response: 27Hz – 30kHz
Sensitivity: 93dB/W/m
Woofer: HOP Cone
Mid-Range: 60mm HDLD (High Density Layered Diaphragm)
Mid-Range: 50mm Ferrite Magnet
Tweeter: 10mm Piezo Magnet
Price :RM 258!!!!!
For those interested in Sony, here is a good news, we offered few package (Value Buy)!!!
Component set + Sony Amplifier + Sony woofer
NOW WE ONLY SELL RM 1198!!!!!
Component set + Sony Amplifier + Sony woofer + 6X9 coaxial 3 way
NOW WE ONLY SELL RM 1468!!!!!
Component set + Sony Amplifier + Sony woofer + 6.5" coaxial 2 way
NOW WE ONLY SELL RM 1388!!!!!
With purchase of Component set + Sony Amplifier,
OR
With purchase of Sony Woofer + 6.5" coaxial 2 way + 6X9 coaxial 3 way
we will FREE 2 pair of RCA cable for you.!!!!
*wiring included. speaker wire, 8 gauge power cable, FUSE Amp, RCA cable 2pair (Front + SUB)
For those interested, please call or PM me ...... 012-3870968(Felix) or 019 6659960(Andrew)
price updated and package added...............
