SEG AE101 rear disc brake
ltl
Miri
itended to change my ae101 rear drum brake to solid disc break, but i hv some questions to ask around here.
hv visited 1 chop shop and found that got two different prices for rear disc brake, that is
1st - with complete arm set
2nd - without arm set (more cheaper)
is it necessary to buy the complete set with arm set? or i can get the cheaper set without arm set and use back my original drum brake arm set?
thks.
you can double check with mechanic:
- arm set is needed if you use different chasis, like AE92 upgraded to AE101 disc brake
for your case, might be not needed if ur current chasis is EE100/AE101.
p/s: i got 1 pair rear ae101 disc brake for sale, cheap2 with handbrake cable
:regular_smile:
SEG AE101 disc brake
can i remain to use my 14" rim after changing the rear disc brakes? understand the dics rotor is bigger than drums brakes right.
14" is fine if you use single pot calipper
if twin pot, got to be 15" at least
I hv one 4 sell. Ae111 knucker wif Ae92 disk in very good condition. Thick brake pad and nice lining (No need to skim and no rust). Rm200. If interested pls call 012-2881509
ello sifoos.. which model the rear disc size is smaller or same with the front disc for ae101(local)??
