Save money on fuel costs
jeffayn
Klang
[font=&quot]10 TOP TIPS FOR FUEL EFFICIENT DRIVING[/font]
1. Minimise your vehicle use
Plan to do a number of errands in one trip rather than several trips and save both time and fuel. Try to avoid short vehicle trips by walking or cycling, this will save over a quarter of a kilogram of greenhouse gas emissions per kilometre of vehicle driving it replaces. Also avoid peak-hour traffic whenever possible.
2. Drive in high gear
The engine runs most efficiently between around 2,000 and 2,500 rpm (lower in diesels). To maintain these low revs you should change up through the gears as soon as practical and before the revs reach 2500 rpm. Potential Saving 20%
3. Drive smoothly
Avoid unnecessary acceleration Drive at a good distance from the car in front so you can anticipate and travel with the flow of traffic. This avoids unnecessary acceleration and frequent repetitive braking that ends up wasting fuel. It's also far safer.Potential Saving 10%
4. Minimise fuel wasted in idling
Minimise fuel wasted in idling by stopping the engine whenever your car is stopped or held up for an extended period of time. By having the engine switched off, even for a short period, you will save more fuel than is lost from the burst of fuel involved in restarting the engine. The net increased wear and tear from this practice is negligible.Potential Saving 5%
5. Speed kills economy
High speeds result in high fuel consumption. At 110 km/h your car uses up to 25 per cent more fuel than it would cruising at 90 km/h.
6. Minimise aerodynamic drag
Additional parts on the exterior of a vehicle such as roof racks and spoilers, or having the window open, increases air resistance and fuel consumption, in some cases by over 20%.
7. Look after your vehicle's tyres
Inflate your vehicle's tyres to the highest pressure recommended by the manufacture and make sure your wheels are properly aligned. Looking after your tyres will not only reduce your fuel consumption it will also extend tyre life and improve handling.
8. Use air conditioning sparingly
Air conditioners can use about 10 per cent extra fuel when operating. However, at speeds of over 80 km/h, use of air conditioning is better for fuel consumption than an open window.
9. Travel light
The more a vehicle carries, the more fuel it uses; an extra 50 kg of weight can increase your fuel bill by 2 per cent.
10. Service your vehicle regularly
Keep your vehicle well tuned and reduce greenhouse gases by up to 25 per cent.
