Sard Pro Meter EL
Sard Pro Meter EL
D`s Garage
7,000 RPM
1. An Electro-Luminescent Backlight is used in this series so as to evenly light up the whole face of the dial, making it easier to see when you drive at night. As the Electro-Luminescent series does not generate heat when emitting light, there will be no harm to the function of the high-precision meter.
2. Peak - hold and warning function are provided on all electrical meters.
3. Pressure meter indicates measurement in KPa.
4. Custom sensor is used in each sensor for precision and durability.
5. For visibility, the wide numeral display is easy to read.
6. Electronic version with peak-hold function
7. Warning function - adjust pressure or temperature by using the front panel switches. The warning light will come on when the pressure or the temperature reaches its pre-set level.
8. Output terminal - The output terminal of the body transmits driving data to external devices like a data logger.
Interested please contact us @ [email protected]
We are located in Bandar Sunway beside Sunway College.Behind Works Engineering.
012-2206117 (Denny)
016-9973300 (MATT)
Hi Bro, how much for water temp?
:wavey:
---------- Post added at 03:05 PM ---------- 6 hour anti-bump limit - Previous post was at 12:30 PM ----------
:wavey:
:listen:
---------- Post added at 02:12 PM ---------- 6 hour anti-bump limit - Previous post was at 10:20 AM ----------
:wavey:
---------- Post added at 05:16 PM ---------- 6 hour anti-bump limit - Previous post was at 02:12 PM ----------
:wavey:
:wavey:
---------- Post added at 05:57 PM ---------- 6 hour anti-bump limit - Previous post was at 12:21 PM ----------
:wavey:
---------- Post added at 08:40 PM ---------- 6 hour anti-bump limit - Previous post was at 05:57 PM ----------
bump bump
:wavey:
---------- Post added at 06:25 PM ---------- 6 hour anti-bump limit - Previous post was at 12:54 PM ----------
:wavey:
:wavey:
---------- Post added at 05:22 PM ---------- 6 hour anti-bump limit - Previous post was at 01:50 PM ----------
:wavey:
:wavey:
---------- Post added at 03:03 PM ---------- 6 hour anti-bump limit - Previous post was at 11:32 AM ----------
:wavey:
:rofl:
---------- Post added at 02:27 PM ---------- 6 hour anti-bump limit - Previous post was at 11:04 AM ----------
:wavey:
---------- Post added at 06:42 PM ---------- 6 hour anti-bump limit - Previous post was at 02:27 PM ----------
:wavey:
---------- Post added at 10:13 PM ---------- 6 hour anti-bump limit - Previous post was at 06:42 PM ----------
:smokin:
