REV Performance Garage Sales !!
andysky5
- All Parts are New and Genuine, unless stated otherwise.
- We provide Warranty for our Products...so you have no worries if anything goes wrong !!
:biggrin:
Engine Performance parts :
BPi Velocity Stack USA - HOT!!
WORKS Enginnering Products
Fuel Bank Evo II - HOT !!
http://www.zerotohundred.com/newforums/engine-and-performance/307090-ngk-iridium-ix-spark-plug.html
Denso Iridium Power Spark Plug
http://www.zerotohundred.com/newforums/engine-and-performance/305020-nrg-racing-meters.html
EPS Power Charger
http://www.zerotohundred.com/newforums/engine-and-performance/305995-original-sard-fuel-regulator.html
http://www.zerotohundred.com/newforums/engine-and-performance/244692-fuel-regulator-high-quality.html#post3131405 - Hot
Works Engineering Ball Bearing Air Charger
Super Ignite RSD
http://www.zerotohundred.com/newforums/engine-and-performance/298913-performance-plug-cable-9-8mm.html#post3792131
http://www.zerotohundred.com/newforums/engine-and-performance/286625-original-tial-wastgate-38mm-and-44mm.html#post3635092
Tial style Wastegate
http://www.zerotohundred.com/newforums/engine-and-performance/312641-tial-mvs-wastegate.html
Turbosmart Wastegates
Manual Boost Controller - Various Type
http://www.zerotohundred.com/newforums/engine-and-performance/240161-hks-super-sqv.html#post3085107
http://www.zerotohundred.com/newforums/engine-and-performance/289046-greddy-type-rs-blow-off-valve.html#post3666210 - New
Adjustable Fuel Regulator (OEM type)
http://www.zerotohundred.com/newforums/engine-and-performance/349996-skunk2-intake-manifold.html
Throttle Body 65/70/80mm
Super90 Billet Throttle Body - HOT !!
http://www.zerotohundred.com/newforums/engine-and-performance/350884-works-adjustable-cam-pulley-for-most-cars.html
http://www.zerotohundred.com/newforums/engine-and-performance/293313-p2r-adjustable-cam-pulley.html#post3718084
http://www.zerotohundred.com/newforums/engine-and-performance/209411-aluminized-thermal-cloth-for-sale.html#post2779699
Aluminium Pulley Kit
http://www.zerotohundred.com/newforums/engine-and-performance/246892-high-capacity-fuel-rail-kit.html#post3159660
Honda B16a/B18c Vtec Adjustable Cam Pulley
http://www.zerotohundred.com/newforums/engine-and-performance/250888-firehill-exhaust-thermal-wrap.html#post3206738
http://www.zerotohundred.com/newforums/engine-and-performance/255231-oil-catch-tank-for-sale.html#post3259429 - New
Cusco Oil Catch Tank
Nissan SR20 Performance Parts
http://www.zerotohundred.com/newforums/engine-and-performance/257956-thermal-intake-manifold-gasket.html#post3292161
http://www.zerotohundred.com/newforums/engine-and-performance/258029-ngk-power-cable.html#post3292969
Bubble remover tank / Breather tank
http://www.zerotohundred.com/newforums/engine-and-performance/266165-magnetic-oil-sump-nut.html#post3387651
Skunk 2 Resevoir Cover
Engine Damper Kit
http://www.zerotohundred.com/newforums/engine-and-performance/297523-power-enterprise-timing-belt-2.html#post3894473
http://www.zerotohundred.com/newforums/engine-and-performance/271319-walbro-255-lph-fuel-pump.html#post3448607
http://www.zerotohundred.com/newforums/engine-and-performance/301315-stainless-steel-turbo-manifold-for-gsr-4g93t-evo123.html#post3827166
http://www.zerotohundred.com/newforums/engine-and-performance/310730-performance-intake-manifold.html
http://www.zerotohundred.com/newforums/engine-and-performance/313210-tomei-camshafts-for-4g93-evo123-and-other-cars.html
http://www.zerotohundred.com/newforums/engine-and-performance/332048-piper-racing-camshafts.html#post4238110 - New
http://www.zerotohundred.com/newforums/engine-and-performance/322114-hot-bits-ss-extractors-for-various-cars.html#post4112457 - HOT !!
Spoon Reservoir Cover - Nice !!
http://www.zerotohundred.com/newforums/engine-and-performance/336829-transparent-timing-belt-cover.html#post4299049
http://www.zerotohundred.com/newforums/engine-and-performance/325211-cometic-metal-head-gasket-for-various-cars.html#post4158295
Turbo Charger
EXEDY Racing Clutch
http://www.zerotohundred.com/newforums/engine-and-performance/328350-triniti-racing-clutch.html#post4201311 - NEW
T-Bolt Hose Clamps
Greddy & Cusco Performance Engine Oil
KAAZ Transmission Gear Oil
http://www.zerotohundred.com/newforums/engine-and-performance/367199-engine-mounting-full-rubber.html#post1063437982 - NEW
**Fuel Injector Cleaning Service
* Dynamic Engine Balancing Service - NEW
JUN Racing Camshaft
Matspeed Performance Camshaft
Jasma Performance Camshaft
RACE-TECH Smooth Shift Bushing
Racing Oil Pump for 4g9x Engine
Dynatek ARC-2 Ignition Booster
Cooling Mist Water Methanol Injection Kit
ACL / King Engine Bearing
CP/ Wiseco/ Supertech (Forged Pistons)
Duratech Con-rod (Connecting Rods)
ARP Head Studs
Engine Oil Cap
Breather Filter
HKS & VP octane booster & engine cleaner
Hi-Tech Stainless Steel Extrator for Honda B series & Mitsubishi 4g9x
Super Single Racing Clutch for Mitsubishi GSR CK Turbo
WORKS Alloy Aluminium TT Crank Pulley
KAAZ LSD Limited Slip Differential - HOT
Intake System & Filter
http://www.zerotohundred.com/newforums/engine-and-performance/365764-k-and-n-drop-in-and-open-pod-filter-offer.html#post1063422225
Apexi Power Intake
http://www.zerotohundred.com/newforums/engine-and-performance/262624-open-pod-air-filter-intake-kit.html#post3344234
WORKS Engineering Drop in Filter
Project S Super Stainless Drop in Filter
http://www.zerotohundred.com/newforums/engine-and-performance/245966-hks-super-power-flow-reloaded.html#post3147438
http://www.zerotohundred.com/newforums/engine-and-performance/274804-hks-replacement-filter-element-dry-3-layer.html#post3490645
Stainless Steel Filter
Real Carbon Filter
UTR Super Flow Performance Drop in Filter - hot
http://www.zerotohundred.com/newforums/engine-and-performance/249157-simota-twister-for-honda-eg-ek.html#post3186142
Pipercross cold air Intake duct
http://www.zerotohundred.com/newforums/engine-and-performance/250109-cool-air-intake-kit.html#post3197487
http://www.zerotohundred.com/newforums/engine-and-performance/250908-intake-air-ram-kit.html#post3206969 - New
Aluminium Piping
Mugen Air Box
Electronics
http://www.zerotohundred.com/newforums/interior-and-cockpit/304330-nrg-meters.html - NEW !!
http://www.zerotohundred.com/newforums/engine-and-performance/310716-e-drive-throttle-controller.html - NEW
http://www.zerotohundred.com/newforums/interior-and-cockpit/255885-sports-meter-defi-style.html#post3266125 - New
Pivot Shift Lamps - New
http://www.zerotohundred.com/newforums/engine-and-performance/299990-apexi-afc-neo.html#post3807555
http://www.zerotohundred.com/newforums/engine-and-performance/292447-greddy-emanage-blue.html
Pivot Speed Meter V
http://www.zerotohundred.com/newforums/engine-and-performance/283404-pivot-raizin.html#post3596724
http://www.zerotohundred.com/newforums/interior-and-cockpit/266932-apexi-el2-boost-meter.html#post3396272
Shift Lamp
V-Manage Ignition Amplifier
http://www.zerotohundred.com/newforums/interior-and-cockpit/264060-apexi-pen-timer.html - New
Turbo Timer
MTX-L: Wideband Air/Fuel Ratio Gauge
http://www.zerotohundred.com/newforums/interior-and-cockpit/283063-engine-start-button-2.html - Hot
Ignition Earth
http://www.zerotohundred.com/newforums/engine-and-performance/246446-grounding-cable-kit.html#post3153704
Direct Ignition Panel
http://www.zerotohundred.com/newforums/interior-and-cockpit/250951-volt-meter.html
http://www.zerotohundred.com/newforums/engine-and-performance/254233-electric-fan-temperature-controller.html#post3246899
HKS Style Grounding Cable Kit - Hot
Electronic Boost Controller
Silicone hoses :
http://www.zerotohundred.com/newforums/engine-and-performance/246291-silicone-radiator-hose-kit.html - New
Samco Silicone hose
http://www.zerotohundred.com/newforums/engine-and-performance/220354-samco-silicone-vacuum-hose-for-sale.html#post2880078
http://www.zerotohundred.com/newforums/engine-and-performance/230846-silicone-elbow-and-reducer-for-sale.html
HKS Vacuum hose
Cooling parts :
http://www.zerotohundred.com/newforums/engine-and-performance/243511-dei-performance-coolant-additive.html#post3119285 - Hot
http://www.zerotohundred.com/newforums/engine-and-performance/191029-performance-aluminium-radiators-for-sale.html
Wira, Satria, Putra, Evo and Civic eg/ek Performance Radiator
http://www.zerotohundred.com/newforums/engine-and-performance/298926-honda-eg-ek-aluminium-radiator.html
http://www.zerotohundred.com/newforums/engine-and-performance/358430-aluminium-radiator-cooling-plate-air-diversion-plate.html#post1063330946 - NEW !!
Engine Oil Cooler Kit - New
Engine Oil Cooler
http://www.zerotohundred.com/newforums/engine-and-performance/260890-intercooler-hks-style.html#post3326087
ARC Intercooler
Automatic Transmission Cooler Kit
http://www.zerotohundred.com/newforums/engine-and-performance/283058-electric-fan-performance.html#post3592057
http://www.zerotohundred.com/newforums/engine-and-performance/346817-low-temp-sports-thermostat.html#post4418837 - New
Synergy Radiator
ARC Aluminium for Proton EVO/GSR and Honda Civic
Braking system :
PRO-RS Braided brake hose
High Performance Brake Pads
Brembo Brake Fluid
Sports Brake Rotor
Brembo Brake Disc Rotor - NEW
VTTR Break Kits
Skunk2 rear lower arm for Honda Civic EG/EK
Interior / Exterior and Body parts :
http://www.zerotohundred.com/newforums/interior-and-cockpit/289016-works-teflon-gear-knob.html#post3665700 - New
http://www.zerotohundred.com/newforums/interior-and-cockpit/267605-bride-low-max-seat.html#post3407804
Philips crystal vision
Real Carbon Plate
D1 Bonnet Pin
Sparco bonnet pin
Sparco Rear Pin / Hook
Aerodynamic Number Plate Holder - New
http://www.zerotohundred.com/newforums/engine-and-performance/310938-gear-short-shifter.htmlRECARO Seat DC5 - Black
Suspension parts :
HWL Full Adjustable Suspension - NEW !!
HWL Adjustable Suspension - HOT !!
Adjustable Suspension Kit For Proton Cars
Ultra Racing Chassis Stabilizer Bar
BC Racing Adjustable Suspension - HOT !!
http://www.zerotohundred.com/newforums/chassis-and-wheels/330480-bc-racing-adjustable-suspension.html#post4221429
GAB Suspension
Rear Lower Arm bar
Suspension kits for Nissan RWD cars
Honda Adjustable Suspension kit
POWERFLEX Polyurethane Bushing
Rear Suspension arm for Proton Wira, Putra and Satria - New
Room bar
Adjustable Front / Rear Camber & Toe Kits
SuperPro Polyurethane Bushing
HARDRACE Adjustable Suspension ARM
Car Audio :
Focal and Zapco products
Others :
Alloy wheel nuts
Sports Wheel Nuts - New
Oil Temp/ Pressure Sensor & Cooler Adaptor
Water Temperature Sensor Hose Adaptor
http://www.zerotohundred.com/newforums/all-other-stuff/377155-samco-silicone-hose-key-chain.html#post1063546957 - CooL :D
[MAP] Sunway, Petaling Jaya, Selangor, malaysia[/MAP]
Address :
No.7, Jalan PJS11/24,
Bandar Sunway,
46150 Petaling Jaya, Selangor.
Note: Rev Performance (1st floor above F3 Racing Technology), same row as Teck Ming Silverstone tires near N1 racing.
Operating Hours : Monday to Saturday ( 11am - 7pm )
Please pm or sms for COD at Rev Performance, Bandar Sunway or Postage by GD Express ( postage will be charged ).
My contact no. is : 017-3526055 (andy)
Bank In Details :
Bank : Maybank
Account no : 112231051159
Name : Low Chun Hung
More products coming soon !! TQ :burnout:
do u still have d k & n drop in air filter for myvi 1.3?
