ralliart colt plus
fct
kluang,jb,spore
Engine
Type 4G15 MIVEC Turbo
Cylinder In-line 4 / 16-valve DOHC
Bore x Stroke 75.5 x 82.0
Displacement 1468 cc
Compression Ratio 9.0
Max Output 108(147)/6000 kW(PS)/rpm
Max Torque 180(18.3)/2500 N.m(kg.m)/rpm
Fuel System
Type ECI-Multi
Fuel Tank Capacity 45 litres
Transmission
Type INVECS-III 6-CVT
Gear Ratio - 1st 2.319
Gear Ratio - 5th 0.445
Gear Ratio - Rev 2.588
Final Gear Ratio 5.219
Steering
Type of Gear Rack & pinion with power assist
Suspension
Front MacPherson strut with coil springs and stabilizers
Rear Torsion beam with coil springs and stabilizers
Brakes
Front Ventilated disc
Rear Solid disc
more pics http://www.mitsubishicars.com.sg/download/Brochure_Colt_Plus.pdf
