quetion:Bolt on turbo kit!
aries
All sifu~
If kenari(auto) original engin bolt on turbo kit~what should we need to taken care after installation complete?boost can to up how many bar?did the original piston easy boom? plsss~~give me some comment to using ori engine bolt on turbo~
boosting for a BOT is normally quite low...about 0.5bar..
changing ur gasket to a metal one shud allow u to boost a lil higher..
it wont blow if u dont keep "tekan-ing"
aries said:
All sifu~
how many bar?? it depends what ur kit setup..if no metal gasket and piggyback ECU..plz put below 0.4 Bar..if Got piggyback can reach 0.4 - 0.5Bar..if got metal gasket..and colder plug = 0.5-0.6 bar, if u put xtra injector & controller can go max 0.9Bar..after that just change low comp piston...
4896..which workshop u send the kelisa?
for blot on turbo?
care to share your kits ?
Pls do a search. This topic was dicussed trillions of times.
