Problem;;;
swap aka SWAP
PENANG/IPOH
can any 1 tell me wat i facing now..no see my pomen yet..but if somebody hav facing these prob..these raya time..me go to uneven road..many hole road lar..like snake also..after back to ipoh..suddenly my left side front producing like vibrating sound.."greer..greer.." sound..like some thing loosing..than when steering turn right no sound..turn left got "krik..krik.." sound..some of my member said the steering rack left side already kong...is that true..
i face that problem before...i cant remember what is that thing la...but need to replace some part la cost around 80 ringgit...
wah...
like that must change new engine ler!!! heheheeee....
joking onli!!!!! jgn mare!!!
like you sadi ler... something loose...
cheers...
yeah la bro..
like bro sham said...
something loose...
or mebbe thats the birth sound of ur driveshaft???heheheheheeee...
me kena like that also last time...
the sound at first kinda cute though....
laariiii...!!!!
check and see the steering rack la .. this one definately need to jack up the car to check lor ..
can it be the wheel bearing...the left side..coz behind the brek..alot of oil leak la..not brek leak..but like grease..compare to right side r clean..
my fren got this prob
if engaging from 1st gear got some vibration..around stereng rack...whats the cause?vibration only from static to 1st only...other gears dun have
ur fren using any racing clutch? or try to check the mouting near the steering rack there:regular_smile:
no..normal bt clutch..problem occured only recently during free--->1st gear
if that mounting..whats the cost?
got 2 sets of good condition steering rack complete wif tie-rod-end......
Check your outer CV join's cover.
hmmm i think the cost is around RM100+- like that gua, hehe i also haven change b4:_:
ha..ha..already when to ahyau..the left side rod connet to wheel nut sudah loose..my pomen juz tighten it..than solve..next time i can do my self...
which one...?
the center one with pin and one nut aaaa ???
drive shaft nut aaa ???
