Problem Usage of HKS Turbo Timer Type - 1
Calz83
Ipoh/KL
Halo to all sifu...!!! I've install de HKS turbo timer type-1 n I've problem of using it... I've check through de net n it shows a lotz of function on it but the problem is how to use it...??? I'm not very sure which button i need to press in order to activate de function... So i'm here would like to ask any sifu can help me out with this problem... Pretty stupid user over here.. Hope u guys dun mind... Thanks... so any sifu mind to share some knowledge...??? Thanks a lot....!!!!!! :biggrin:
just push push the button and learn loh... aiyah, i also got manual but too lazy to read instead of just explore yourself
by the way, the only thing you need to refer is the setting, you need to set the turbo timer to get the accuracy!
Aiyoh...
I've trade my apexi turbo timer with this one(HKS) from my frz n he has lose de manual lerr... Anyway any sifu mind to show me de correct way to use it...??? Thanks.. Highly appreciate...!!!!
Thanks 4AGZE
Thanks bro... I'll try to do so but dunno it works or not...!!!! By the way would u mind to borrow me to have a photocopy of de manual book....??? Just asking for a help.. Is ok if de manual book is P&C for u....!!!! Thanks by the way..!!!! :biggrin:
no probs... but i need to find first... can make a copy for you
try search on google, u can download the manual frm there.....
kwai, not easy to find the HKS TT Type 1 manual in english ler... took me few days to get it :D thanks google...
got conected properly or not?
las time i send my car to instal Blitz mstt...the fuxking wireman juz conect the timer function...other functions all cannot use...
check it out 1st
if al conect properly...juz play the timer by ur finger.....should be easier for u to understand...if stil cannot..then u hv to refer the manual (from 4agze) n try to play...ehehe
Thanks 4AGZE in advance... Really hope can hear the good news from u... I'll treat u a meal after this... Thanks...
Thanks kwai.. But I've try to search from de net.. But de search is zero...!!!! :o(
check it out 1st
Connected correctly n everthing is fine the only thing is me(stupid user)... I dun really know how to use it.... I just know pressing (m) button is stop the timer then the rest i not really sure what it is use for... Kinda stupid over here...!!! hope u guys dun mind...
may be u have not try hard enuff.....
m= menu
s = sub-menu
button on right side is + and -
i didnt try very hard because i already have the japanese manuals la... just wanted to find the english for future only... in case i wanted to sell :)
hahah..i used to have this timer, din reli play much with the functions, too much to play with, all i played was the speed, rpm, shift light, voltage, timer , and i gues thats all. dun reli know how to play with the 0-100m etc time. happy playing with ur timer..
aiks, yaloh, got shift lights... almost forgotten that... :p
found it in google...less than 5 seconds
Google... ur friend in need!
http://www.mr2.com/TEXT/hks_tt.html
Operation of Turbo Timer
If you didn't receive any english instructions on the operation of the timer,
here is a brief synopsis of the functions:
The timer has two basic modes of operation, TIMER mode and ADD mode.
TIMER Mode
ON/OFF - Turn the timer on or off. Unless the timer was manually turned off,
the timer will automatically turn ON (but not activate) with the
ignition each time the vehicle is driven, and the time previously
selected will also be retained in memory.
SELECT TIME - To select the idle time, press the UP or DOWN button to toggle
to the desired time. The available selections are as follows:
0.00s - 0.30s - 1.00s - 1.30s - 2.00s - 2.30s - 3.00s -
4.00s - 5.00s - 6.00s - 7.00s - 8.00s - 9.00s - 9.59s -
9.99s
RESET TIME - To reset the time to 0.00s, press the UP and DOWN buttons
simultaneously for at least 1 second.
ALTERNATING DISPLAY - To make the display alternate between the initial time
selected and the time remaining in the countdown, press
the UP and POWER buttons simultaneously for at least one
second. (Be sure to press the UP button first) Press
the sequence a second time to stop the alternating
display.
RESET TURBO TIMER - To reset all functions and modes (including the cumulative
hours recorded in the ADD mode), press the ALARM and
POWER buttons simultaneously. (Be sure to press the ALARM
button first)
ADD MODE (Engine Hour Meter)
ON/OFF - When the timer is in TIMER mode, press the ALARM and DOWN buttons
simultaneously for at least one second. The cumulative number of
hours the engine has running should appear on the display. To
return to TIMER mode, press the sequence a second time. If the
ignition key is turned OFF, the display will revert to the TIMER
display automatically. The timer will revert back to ADD mode the
next time the car is started. (ie. whichever mode the timer is
in, TIMER or ADD, will be remembered and restored)
FLASHING DISPLAY - The timer can be programmed to flash ON and OFF while in
ADD mode to indicate that the timer is recording the
number of hours of engine operations. To turn the flashing
display on or off, press the UP and POWER buttons
simultaneously for at least one second. (Be sure to press
RESET TIME - To reset the cumulative hours recorded in the ADD mode, press the
UP and DOWN buttons simultaneously for at least one second.
button first)
4agze said:
ok found it, want soft or hard copy?
Anything will do... Soft or hard copy also can.. Which one is more convenience for u...???? As long as i dun bother u too much... Really appreciate ur effort.. Owe u a huge favorrrrrr...!!!! Thanks bro...
