hi everybody,recently i brought an evolution 7.5 GTA from a malay gentlement from damansara,it's a black one shown in 'The Motortrader' recently. When i first drive the car,it seems ok n everything seems normal..After an hour driving the car,i found that the 'Engine Check' light was on,but after i drive it for a while,it was gone again. BUt,it was on again n then off...usually,the period when it was on depends,sometimes 15 minutes,sometimes 1 hour. I went to some workshop to get everything check up,some said there was leaking of air-flow,some said the censor break down,but none of them got the problem fixed..until now,the light was on and off from time to time. Has any evolution owner face the similiar problem before? My car engine was not heavily modified,the previous owner changed the exhaust system, the blow off valve, turbo timer n boots timer. I need some advice from you all since this is my first turbo-charged car, i really wish this problem can be fixed as soon as possible,and i really need help. Thank you.
:sleep:
