Pls HELP....Idling problem with my Cefiro RB20Turbo
kelvin_goh999
Hi guys,
I juz bought a Cefiro A31 RB20Turbo. I got problem with the idling. The problem doesnt occur in the morning. But when I drive for a while and then I off the engine for about 15 to 20 minutes, I start again the engine, the idling becomes very low like n later soon the idling goes to 0 rpm and then the engine off if I dun press the fuel pedal. Juz curious what is the problem? I already change 6 new spark plugs but still the same.
Will it be the coil or wiring? Pls help. Thank you.
Kelvin
My foreman took out the cold start and clean it but still the same. Is the cold start means idling sensor?
clean ur throttle head ler...
nothing to do with the cold start...
clean ur TB...buy a can of carburetor/chke cleaner n spray it....
if ur car got intercooler...take it out n clean inside intercooler..maybe got oil...clean all d IC hoses as well......
should be ok i guess.....
if u r too free for nothing....u may try to reset ur ecu...my 2 cents only
