Pivot Mega Raizin , Powe 7 Core
Yikseetoh
Pivot Mega Raizin
attachment.php
-Improve audio quality
-Increase torque and response and power
-Stabilize idling and improve engine kick over
-Increase headlight brightness
-Improve fuel economy
-Improve battery life
Pivot power 7 Core Grounding cable 5 point
attachment.php
The additional earth wire on our Composite Earth Cable has a conductor circumference 2.5 times the normal wire. This improves the firing speed by reducing voltage loss and increasing conductivity of high frequency waves released by the ignition coil. Moreover, by facilitating ionization during combustion, it improves gas mileage and engine torque.
Improve Combustion
Tin Plated Conductor Wires for Increased Frequency Conductivity. 5.25sq (0.75sq x 7 conductor wires)
Heat resistant to 105°C
Heat resistant to 105°C, Outside Diameter 8mm
Machined Aluminum Heat Radiation Cap and Corrosion Resistant from Battery Gas Tin Plated Electrical Terminal.
Superiorly Designed for Efficient Power Distribution at Ignition
Thickness: 6 GA
7 Power Core Inside a single cable
Improve Ignition system
Increase Dynamoelectric power
Increase Brightness of headlamp
Improve Audio performance
Increase Horsepower Up to 25%
Increase Pick Up 5% - 15%
Improve Fuel Effectioncy Up to 30%
Stabilize Electricity
Improve Battery Power & Life Span
Package for two Rm80 Promotion price:wavey:
