PIONEER DEH-80PRS
Finally, my stocks for the highly acclaimed Pioneer DEH-80PRS have arrived. Replacing the outgoing P80RSII, this unit is priced very affordably and has a plethora of features to droll over. Sound quality on this unit is top notch, and what better way to begin the journey in audio than to have a good and clean source!
In a nutshell, the DEH-80PRS is an audiophile grade headunit that has been made affordable without compromising on sound quality and features. For SQ buffs, the unit comeso with Auto EQ and Auto Time Alignment , features that are ever so popular among SQ buffs looking for the perfect centre staging. Other features to drool over are the Burr Brown 24 Bit D/A converters, a four layer circuit board, High capacitance power supply capacitor, sound master clock circuitry , 28-bit binary floating point DSP and a 3 way digital network. Finally, to add icing to the cake, the unit features a 16 band L/R independent digital equalizer.
The display on this unit is a 3 line Full Dot LCD display and it comes with 3 sets of 5V Hi Voltage RCA outputs for minimum distortion from your amplifiers. The unit also supports multiple playback formats including USB, SD and CD support. Finally, the display allows for custom illumination so you can choose the desired colour to match your car's interior lighting.
The DEH-80PRS : Uncontended in it's price range.
For detailed specifications and features, check out the spoiler below :
The best views of this unit :
http://img502.imageshack.us/img502/4075/img8894x.jpg
http://img703.imageshack.us/img703/9300/img8893k.jpg
http://img845.imageshack.us/img845/2812/img8892b.jpg
http://img85.imageshack.us/img85/3101/img8896h.jpg
Full package and in terms of hardware, it is exactly the same as what you get in the shops ( At less than 3/4 the price outside! ) .
As it is always our motto to share with you guys the best for less, we are currently selling these units at a promotional price of just /HARI RAYA PROMO@RM1450 + FOC 4GB THUMBDRIVE!! nett. ORDER NOW!
COD around Kelana Square ( Office Hours ) and Kelana Jaya / Aman Suria / Ara Damansara / Citta Mall / Tropicana / One Utama / Sunway / Subang / PJ / SS2 at night.
For courier, an additional RM10 for Peninsular Malaysia and RM20 for East Malaysia is all that's required for the units to be sent directly to your doorstep.
Call me now at 0123913788 to deal.
* Audiophile Grade Internal Components for the Ultimate in Sound Quality
* 28-Bit Binary Floating-Point DSP and 3-Way Digital Network
* 3 Hi-Volt RCA Preouts (5V)
AUDIOPHILE GRADE
The DEH-80PRS CD receiver features audiophile grade internal components and materials that are carefully selected to achieve Pioneer's highest standards for the ultimate in sound quality. Pioneer’s exclusive sound field technologies including Auto EQ and Auto Time Alignment help optimize audio in ways that perfectly suit particular listening spaces and allow subtle manual control of settings. Versatile connectivity helps deliver exceptional sound quality from various digital devices.
Burr-Brown® 24-bit D/A Converters: Three Burr-Brown digital to analog converters are used - one each for the high, mid, and low frequency ranges - providing exceptional linear sound reproduction with wide dynamic range and faithful reproduction of the original source
Four-Layer Circuit Board Design: Utilizing a four layer copper foil board with components mounted to both sides of the board allows for a circuit board with a much smaller footprint. The inside layers of the circuit board are dedicated to the power and ground supply traces, which allow for lower overall circuit impedance and greatly reduce noise.
Full-Custom High-Capacitance Power Supply Capacitor: Custom-built capacitors in the power supply keep sound clear and consistent. Exclusive parts are developed and tuned for optimal sound quality through a thorough review of materials and repeated listening trials.
Sound Master Clock Circuitry: Timing is everything. Our new Sound Master Clock generates waveforms that read and process digital signals with extraordinary precision - eliminating jitter. Finely detailed signals can be accurately reproduced as they were intended.
28-bit Binary Floating-Point DSP: Handling a wider range of complicated calculations than a standard fixed-point DSP, Pioneer's 28-bit binary floating-point DSP along with the use of advanced programming technology allows for highly precise sound processing and tuning without degrading the source's digital signal.
3-Way Digital Network: The DEH-80PRS features a 3-Way Digital Network, connecting (via three 5V RCA preouts) up to three external amplifiers, each dedicated to driving high-, mid- and low-frequency ranges, respectively. The result: more distinct separation of the three frequency ranges, for more full, natural sound realizing more of each speaker’s potential in a multi-speaker system.
L/R Independent 16-Band Digital Equalizer: The L/R Independent 16-Band Digital Equalizer is excellent at overcoming in-vehicle frequency response peaks and troughs. With fine tuning adjustments at 2/3 octave steps, tailoring the frequency curves to generate a flat response is possible in any type of car.
Auto Time Alignment and Auto EQ: Time alignment automatically estimates the delay from each speaker to the driver’s position and adjusts speaker sound output timing, so that sound from all speakers reaches the driver’s ears in perfect sync. Auto EQ tailors specific musical characteristics according to preference, uses a microphone to monitor and analyze acoustics, then automatically fine-tunes all frequency bandwidths and front and rear speaker digital parametric equalization. These processes occur in 399 seamless steps in just about 6 minutes and 30 seconds.
Time Alignment: Not only can this function precisely adjust each speaker’s output timing according to its distance from the listening position – it is also adaptable to a 3-way multi-amplifier and speaker system.
USB DIRECT CONTROL FOR iPOD®/iPHONE®
Pioneer's DEH-80PRS is ready to roll with direct connectivity to your iPod or iPhone for audio playback via the optional USB interface cable (CD-IU51 interface cable sold separately). Song, artist, time and album information are displayed on the full dot LCD display. Powerful tools such as Link Play and Alphabet Search to help you find content faster. The system's wired USB connection provides direct digital signal transfer from the device for clean, clear sound while providing 1 amp of current to keep your iPod/iPhone charged.
Dual rear USB ports allow connection of 2 compatible USB devices so you will never run out of source options. For example, you can connect an iPod to USB1 and a compatible USB hard disk drive to USB2.
CUSTOMIZE IT
Match the display and key illumination to your vehicle's interior lighting. Over 210,000 colors are available to match the illumination in any car. The key illumination and display illumination colors can be customized separately for an endless number of color combinations.
OTHER FEATURES
Full Dot LCD Display (192 x 48 pixels, 3-line)
Built-In MOSFET 50W x 4 Amplifier
3 Sets of Hi-Volt RCA Preouts (5V) for System Expansion
Dual 16-Band Graphic Equalizer
Auto EQ (CD-MC20 required)
Advanced Sound Retriever
SD/SDHC Memory Card Slot
Wired Remote Input
Included Remote Control
Anti-Dust Design
Flap Face
Detachable Face Security™
AUDIOPHILE GRADE
CUSTOMIZE IT
OTHER FEATURES
Wired Remote Input
Anti-Dust Design
Flap Face
