bertdeen30 said:hybrid 1500-200 ? i,m selling 1 fin td05 with the one can plug on with exhaust manifold ..dont know u interest anot ..im using td07/06 t67 housing with 25g..on vr4 engine also ..with other mod together is sure ler heheh~ but good working also
bertdeen30 said:the whole set turbine and the stand contact with the exhaust manifold
..using ori ecu and ori injector..but top end good pick up 1,2,gear not that good lo...changing injector to e5 or rx7..and ecu changing to haltech e6k. ..dont know gearbox want to do ratio or change to 4wd only change eratio .. crank wanted to lighten also ..keke...why u want modification .find me lo..i help my boss do modification ..me a trainee only sia~ in sunway area lo,.
threebond said:Hello RS..
tentang turbo tu..kalau awak nak turun Seremban awk call saya...
Kalau awk turun Shah Alam ker..boleh jumpa saya.sya stay kat PJ ajer. i show u the TDO5 (EVO with Garrett Stuff)
awak ader no saya kan..anything drop your call..about the TDO5 Garrett tu..still available lar.cuma tunggu awak petik price ajer.all Part is new stuff & material.Bukan recond punya barang just turbine & compressor housing only - Re-Manufacture
*U want to use on the road or drag..
yo rs gang...
i have 1 unit kkk k24 turbo taken out from audi quartro 2.2l i think. exhaust housing bigger than tdo5 evo 3 but then compressor almost the same...
no shaft play...spools better than a evo3 tdo5h 16G big!.....good for 3-450 hp upgrades. proven on a vr4 already...but then must place an adapter flange fro manifold outlet to match the turbine inlet flange.
it uses an external 35 mm wastegate which is more efficient than internal ones...
price rm 1K nego for the turbine oni.
wastegate additional rm 300
interested pls cal or sms me at 012 4767163( chew)
threebond said:hehe..is it proven with your car my bro??actually nice item..but if u need a adapter flange from manifold itu dah kire LECEH punya keje.im also have one ORI Garrett t3/t04e (and im using it now in my car.)
so for the KKK how is it performance like.The respond early/end stage, and im also want to know about the spare part.is it easy to get spare part like Garrett?? because your words sound like this KKK is more much better respond than E3 16G - how about compressor E3 16G with Garrett material ?
he he he he..
anyway good luck to you bro.
