Performance parts for sell
huckaik
ELECTRONIC
1. HKS FCD BOOST CUT FOR MIT (RM 150)
2. HKS FCD BOOST CUT & RPM CUT FOR MIT VR4 4G63 (RM 200)
3. HKS SLD SPEED CUT FOR MIT (RM 150)
4. HKS BOOST CONTROLLER (RM 400)
5. HKS PFC. F-CON COMPUTER BOX FOR MIT VR4 4G63 [wiring & map sensor full set] (RM 850)
6. HKS AIR FILTER BOX FOR MIT VR4 4G63 (RM 150)
7. KNIGHT SPORTS FUEL CUT & BOOST CUT FOR MAZDA FC (13B) (RM 150)
8. EVO 123 WIRING & SENSOR & AIR FLOW & INJECTION EXHAUST SENSOR (RM 1100)
9. VR4 RS WIRING & AIR FLOW SENSOR (RM 600)
10. TOYOTA STARLET TURBO EP71 COMPUTER BOX (RM 300)
FUEL PUMP
2. BOSCH RACING FUEL PUMP 044, 280L, 10 BAR (RM 250)
3. NISSAN BIT FUEL PUMP (RM 100)
4. KNECHT RACING FUEL FILTER, GERMANY [NEW] (RM 50)
INJECTOR
1. DENSO INJECTOR EVO & VR4 550cc (RM 350)
RACING CLUTCH & FLYWHEEL
1. CUSCO RACING CLUTCH & PLATE FOR MIT EVO123 & VR4 & 4G93 [NEW] (RM 1400)
2. CLUTCH FOR MIT MIVEC & PERDANA & 1.8 WIRA japan ( o ) (RM 60)
SARD SILICONE HOSES
1. 6mm, 2 meters [NEW] (RM 60)
2. 6mm, 1.5 meters [NEW] (RM 45)
3. SARD THERMO WRAP 50mm, 10meters [NEW] (RM 300)
EXHAUST
1. APEXI DUNK STAINLESS STEEL FOR NA (RM 450)
2. STAINLESS STEEL N1 3” FOR TURBO (RM 350)
3. STAINLESS STEEL 2” FOR NA (RM 200)
4. VR4 evo123 TURBO OUTLET V DOWN PIPE (RM 80)
5. DASH TURBO TCO5 ADAPTOR (RM 50)
6. HKS (O) HIPER SELENCER (NEW) (RM60)
7. HKS (O) CENTER MUFFLER 3" 90% (NEW) FOR EVO 7 8 9 (RM300)
8. STAINLESS STEEL CENTER MUFFLER 2 1/2" (RM100)
SPARK PLUG & CABLE
1. VR4 RS PLUG CABLE (Original) (RM 100)
2. NGK PLUG 7EA FOR VR4 (RM 50)
3. SPLIT FIRE TRIPLE PLATINUM PLUG FOR VR4 (RM 80)
4. HKS F40RE PLUG FOR MAZDA FC & FD ROTARY ENGINE (RM 100)
5.WIRA PLUG CABLE 1.3 1.5 (O) (RM50)
6.VR4 PLUG COVER (O) (RM30)
7. SUPER TOURING DASH TURBO RACING SILICON PLUG CABLE (RM50)
SUPER LIGHT WEIGHT SPORT RIM
1.WEDS SPORT 15X6.5 OFF43 HOSE 114.3 MADE IN JAPAN VERY LIGHT (RM1800)
SUSPENSION
1. TEIN HA ADJUSTABLE SOFT HARD & PILLOW BALL UPPER MOUNT FOR TOYOTA JZX 100 (F) (RM450)
2. TEIN ADJUSTABLE FOR NISSAN SKYLINE R32 (F) (RM 400)
3. EVO 7 ABSORBER FULL SET (F&R) [Original] (RM 1000)
4. BLITZ V,IS SOFT HARD ABSORBER MAZDA RX7 FC & (R) (RM 250)
5. VR4 PILLOW BOLL UPPER MOUNT (R) (RM 500)
6. JAPAN PILLOW BOLL UPPER MOUNT FOR SUPER TOURING & ISWARA (F) (RM 500)
7. WIRA 1.5 SPORTS RACING SPRING (F) (RM 100)
8. EVO 3 (Original) spring (F) (RM 100)
9. FTO (Original) spring (F) (RM 100)
10. VR4 RS LOWER ARM & ANTI ROLL BAR (F) (RM 150)
11. SUPER TOURING RACING LOWER ARM & ANTI ROLL BAR (F) (RM 100)
12. AROSPEED ROOM BAR UNIVERSE [NEW] (RM 150)
13. R1 RACING ANTI ROLL BAR Bush [NEW] (RM 30)
14.GAB SUPER ABSORBER FOR WIRA (R) made in japan (RM200)
15.MITSUBISHI GALANT VR4 CUSCO (F) STRUT BAR (RM120)\
BRAKE SYSTEM
1. SUMITOMO BRAKE PADS FOR CIVIC EG (F) [NEW] MADE IN JAPAN (RM100
2. WIRA 1.5 DISC ROTOR & BRAKE PADS & CALIPER & KNUCKLE (F) (RM150)
3.MIT VR4 RS BRAKE HOSE (O) (F) (RM50
4.MIT SUPER TOURING DASH TURBO BRAKE HOSE (O) (F) (RM50)
5.WIRA BRAKE HOSE 1 SET (O) (F&R) (RM100)
6.MIT VR4 RACING BRAKE HOSE (F) (RM100)
7.PROTON ISWARA RACING BRAKE HOSE (F) (RM100)
GEAR BOX & LSD
1. LSD JAPAN AFTER MARKET FOR EVO123 VR4 4G93 GSR TURBO (RM 1100)
2. EVO123 4G93 [4WD] LONG SHAFT (RM 100)
3. VR4 & 4G93 & EVO DRIVE SHAFT & CENTER BREARING SHAFT (RM 150)
COOLING SYSTEM
1. VR4 RS & WIRA & EVO 123 RADIATOR (RM 100)
2. RACING OIL COOLER 17 ROW 12” X 11” (RM 250)
3. OIL COOLER 6 ROW 25” x 4” & 2” (RM 100)
4. VR4 RS A/C COOLING COIL (RM 50)
5. VR4 RS A/C SWTCH 1 SET (RM50)
RACING PART & ACCESSORIES
1 .PERSONAL GEAR KNOB (RM80)
2. WIRA 1.3 N 1.5 ALTERNATOR BIT AMP (RM100)
3. WIRA 1.8 MANUAL METER (RM 350)
4. WIRA SIDE MIRROR [1 SET] (RM 80)
5. WIRA 1.6 1.8 ALTERNATOR (RM 100)
6. VR4 & EVO123 ALTERNATOR 75AMP (RM 100)
7. VR4 RS VIPER MOTOR (RM 50)
8. VR4 RS METER CABLE (RM 30)
9. HOT BIT RACING COIL [MADE IN JAPAN] (RM 100)
10. VR4 RS STEERING SHAFT & COLUMN SWITCH & COVER (RM 100)
11. CUSCO BONNET PIN 1 SET NEW (RM 150)
12. EVO 8 RS2 TITANIUM TURBO (RM 2000)
13. MITSUBISHI GALANT VR4 SPEED METER AND RS SPEED METER (RM100)
14. BATTERY RACING ALUMINIUM BRACKET (RM60)
15. HONDA CIVIC SH3 SH4 CARBURETOR K&N FILTER (RM60)
16.CARBING ALUMINUM OIL CATCH TANK (15mm) 90% NEW (RM280)
17. DAIHATSU MIRA L200 TURBO INTERNAL MIRROR FOR KANCIL (RM50)
18. COPPER PRO TORNADO SAVE FUEL & MORE POWER FOR WIRA 1.6 1.8 (RM50)
19. EVO 123 INTAKE TURBO HOSE (O) (RM50)
20. VR4 RS BIOW OFF VALVE & PIPING (RM50)A
21. VR4 RS INTAKE TURBO HOSE (RM50)
22. EVO 123 DISTRIBUTOR (RM100)
23. EVO 123 IGNITION COIL (RM150)
24. EVO 7 HOLOW CAM (O) (RM1000)
25. DAIHATSU MIRA L200 TURBO STEERING (O) (RM120)
SOUND SYSTEM
1. SONY XR7190 [MADE IN JAPAN] (RM 100)
2. ALPHASONIK EQUALIZER (RM 50)
3. MANEX HI POWER STEREO GRAPHIC EQUALIZER 100W+100w(RM100)
4. HONDA CIVIC 2WAY MID RANGE & TWEETER 1SET (O) (RM30)
5. CAR TRAFFIC BIT SOUND SIREN MADE IN USA 5”-6” 90% NEW(RM120)
ORIGINAL LAMP
1. HONDA CIVIC SH4 TURN SIGNAL LAMP (O) (F) (R&L) (RM100)
2. HONDA CIVIC SH4 BUMPER LAMP (O) (F) (R&L) (RM100)
3. HONDA CIVIC SH3&SH4 REAR CENTER FRAME (RM30)
4. HONDA PERLUDE REAR CENTER REVERSE LAMP (O) (RM80)
5.WIRA REAR LID LAMP (R) (R&L) (RM80)
6.WIRA REAR TURN SIGNAL LAMP (O) (R) (R&L) (RM100
7.WIRA REAR NUMBER PLATE FRAME (O) (R) (RM40)
8.CAR SUNROOF COVER UNIVESE 7”-36” (RM30)
9.CAR WIND GUIDE SUNROOF COVER 6.5”-38”(RM50)
CARBING ALUMINUM OIL CATCH TANK (15mm) (RM280)
For any INFORMATION, TECHNIQUE SUPPORT or PRICES kindly contact H/P: 016-4514155
ALL ITEM CAN POST BY COURIER
EXHAUST
2. STAINLESS STEEL N1 3” FOR TURBO (RM 350)----> got pics?
Vr4 n evo racing parts
Bump: PIC IS COMEMING SOON
Bump: GAB ADSOBER
bro, OIL COOLER 6 ROW 25” x 4” & 2” (RM 100) still available or not?
got kit and hoses or not?
sh4 carburator filter?new or used?really interested..
