nOObiE qUestion--> How Do U Bridge a 2-channel AMP?
ayluvb3ech
oug
bros...wanna ask this question..how do we wire it? isit some sortof like this? i attached 2 pix ere...dunno which one is correct..or mabbe both also wrong... ?? ur comments are much appreciated.. =)
http://img484.imageshack.us/my.php?image=parellel6yr.jpg
or
http://img371.imageshack.us/my.php?image=series0ea.jpg
or
Some reference here:
http://www.bcae1.com/bridging.htm
For bridgeable 2 channel amp, you should refer to last diagram, configuration Y.
First, is your amp bridgeable?
If not, don't.
If yes, follow the user manual or label on the amp.
Both options that you provide does not look like that it'll work. So, don't do it that way.
if it is bridgeable, it will written on the amp, box and the manual. never do experiment on it or else it maybe will burn ur amp if it does not have auto cut feature.
its more like +ve from channel 1 to +ve from sub, -ve from channel 2 to -ve from sub. the amp should have some indication on the speaker terminals regarding which terminals to use when bridging.
