New & Used Evo Part
loong1
Used
SARD ADJUSTABLE FUEL REGULATOR RM 300
Evo 7,8,9 ralliart exhaust systems RM 1200
Apexi Boost Meter EL 60 Black RM 300
Pivot Radiator Cap 1.3 Bar RM 50
NeW
KOYO ALUMINIUM RADIATORS (LANCER EVO 4-9) - 3 ROW RM 1800 - N1 selling RM2000
Brian Crower Pro CAMSHAFT X 2 (EVO 4-9) 264,272,280 RM 1800
500PS BOLT-ON TURBO KIT(US Brand) bigger than MR8 - FOR EVO RM 3000
Walbro In Tank High Flow Fuel Pump (255 Lph) RM 400
Fuel Rail (WORKS) RM 350
fuel rail rm 350
TD05H BIG 16G EVO MITSUBISHI PORTED TURBO
Working Pressure 25~30 PSI
Compressor Wheel 16G
Turbine Wheel TD05D
Hot Side .58 5 Bolt Standard Hot Side
This is a big 16G, with 1.89" Inducer and 2.68" Exducer. It is ported and has a bigger internal wastegate which supports 380HP and 550 CFM, The internals use a high flowing turbine stage complimenting an extremely efficient TB03 compressor stage rated at 38lbs/min.
It fits the 4G63 2.0 engine. It replaces the 14B turbo and is a direct bolt on. It comes with mounting bracket. It bolts on. It bolts right on without needing any other parts.
It has a big 16G compressor wheel, Td05H turbine wheel, and a specially designed turbine housing. It is ported and has a bigger wastegate. It replaces the 14B turbo and is a direct bolt on.
Upgrade for Mitsubishi will work with your stock fuel system. 450cc injectors that come stock will be sufficient for this turbo, although it is recommend to upgrade to a Fuel pump such as a Walbro 255, standard pressure.
ori pulley can use ? comes with pulley ?
wah.......michael since when u become evo parts dealer liao :P
no wonder your car run so fast ah.......still always go run some mountains ah :P
Turbine Wheel TD05D
Loong,
Where is the place, to have a better view of the turbo?
Azizi,
Don't waste time on that 16G TURBO lah its same with E3. You might wanna check the 500ps turbo kit our friend selling. What brand and consist of what?turbo,w/g,d/p??
Azizi,
fuyoo ...500PS sia ...can dapat around how much la estimated HP macam tu?
Guestimate (with losses) pun 400++
Instant Mamee Monster lah tu!!! :adore: :adore:
td05h 20g turbo charger+ j-pipe +4g63
big wheel td05h 20G TURBO with installed kit ( perfect for upgrade ) + j pipe ( direct bolt on )+ t28 stainless manifold
-high performance turbo
-stainless steel manifold
-stainless steel j- pipe set
New TD05H big 20G turbo.
SYSTEM: JOURNAL BEARING
COMPRESSOR: A/ R 54
WHEEL DIAMETER 52.5 /68 MM
ACTUATOR 1 BAR
TURBINE: WHEEL DIAMETER 49.2/56MM 640 cfm
COMPRESSOR: A/ R 54
ACTUATOR 1 BAR
Bro pls sms me price and brand to 014 6000016 thank
Used
NeW
500PS BOLT-ON TURBO KIT(US Brand) bigger than MR8 - FOR EVO RM 3000 Sold
Fuel Rail (WORKS) RM350
coming in
motec M800
HKS 3037 turbo
Turbocharger Specs:
brand : TopSpeed
ball bearing turbo 400hp on wheel
* Internal Wastegate Flange
* Trim-T 77
* A/R-T 70
* Trim-C 50
RM 3200 only
hey....selling stuff to mod your car faster to beat the silver evo in sepang or UY oh :P
