New programable ecu software
synchron said:
Any comment about the software??
hi dude,
this software is use for standalone or piggy use? or just chipping? Pls let me know on this. i'm very interested on setting to my car.
thank you
synchron said:
Should not be a problem. I have the basic mapping for the b6 turbo.
is b6 & b8 is same ? how much will cost for setting my b8? do you have the picture of the ECU?
B6 & B8 has different ignition timing and fuel map.
The ecu will have these function:
3D" Fuel and Ignition maps. Configurable ignition and injection outputs to suit different applications
Inputs for water temperature, air temperature, auxiliary temperature (eg turbo), manifold air pressure, throttle position, knock sensor, EGO (exhaust gas oxygen)
Outputs for four injector groups - allows full sequential injection on a 4-cylinder.
Outputs for two igniter groups - allows for wasted spark systems on 4-cylinder, or conventional distributor systems.
Eight configurable auxiliary outputs - four of which are PWM capable.
Adaptive fuel control - with configurable tolerances and loop gains, and conditions under which adaptive behaviour takes place
Narrow-band (factory EGO sensor) closed loop fuel control
High current programmable outputs - allows direct drive of solenoid valves for boost control, air bypass etc
Special function programmable outputs - allows control of anti-pollution purge valves, air conditioners etc
Open-loop and closed loop idle bypass control - allows configuration of increased idle bypass amount based on low battery, electrical load, air conditioner, as well as correction based on RPM
Programmable for different crank angle sensor waveforms
I am still designing the casing for ecu motherboard. Haven decided on the pricing yet, because i have yet to calculate the cost. Just want to launch the software first because they are most important. I want to get as much feedback from the users as possible because i need to know if the software need anymore changes.
Hopefully the test unit for the Synchron Motorsports ECU will be launch in June or July.
i downloaded from the link,but cannot execute la...maybe i'll try again later...
You will need to create a folder in the desktop and extract everything to the folder.
Then only you can run the program.
Wow, software looks cool. Do u have the file for 4g13? is this ment for the MMC or Siemens EU, or both? Where can I get the cable to hook up the comp and the ECU?
This is a fully standalone ecu. Not a piggyback or a chip.
sorry! i dont have anything for 4g13.
How much?
Bro,
Do you have the pricing for the product?
What are the plans for settings and programming?
Am interested in your product
I am still on the edge of finishing the board with some extra in it and also upgrading the software.
Planning to hit the market at RM 2.5k.
What car r u driving anyway?
hi bro... got few question la
- Can used for auto tranny car? heheh
- Any boost control features?
- Injector duty cycle adjustment? (bigger injector w/o idle problemo)
- For vtec, different fuel and ignition map for Hi and Low cam profile?
- support 4 wire O2 sensor?
tq
Got me a wira with a 1.8manual.
Nothing fancy, but thinking bout some mods that will need the ECU
i'll be keeping an eye out for the finished product.
Good luck
