Hi all,
I recently got a tachometer that I want to install to my car. I have made all the necessary power wiring connections. And I have confirmed it using a multimeter.
This is a Defi D-gauge tachometer. If I switch on the lights, the meter would light up. But if I put the ignition to ON, or even start the car, the meter does not move at all.
I took the tachometer signal input from pin 7 on the ECU. Is this the correct way? The manual said to put the tachometer signal to the negative terminal of the distributor. Which I'm not sure where it is.
Another question, is the Accessory(ACC) and Ignition ON wire power up at the same time when the key is turned?
Thanks.
Thanks.
i even cant saw this car in Auto saloon 2009...
