Multi Auto-Turbo Timer with Volt Meter
ftzone
full throttle zone
Penang, Prai
Smalled size (like pivot speed meter X) - pic will upload later.
Turbo Timer with Volt Measurement
or
Volt Meter with RPM measurement with shift light (No timer). (Brand G'Zox)
*RPM Readings suitable for 3cyl, 4cyl & 6cyl. via ignition coil or ECU RPM signal.
Can fine tune for more accurate RPM readings.
User selected rpm warning/shift light
Blue Led Blinking when RPM warning activates.
can display digital RPM readings or volt measurement
http://www.gzox.com/img/logo.gif
Price RM165.00 nego
http://www.gzox.com/race/gt500/2005/img/photo006.jpg
Free shipping to peninsular malaysia
Brand New in BOX with manufacturer warranty.
FREE SHIPPING ANYWHERE IN MALAYSIA!
Add RM35 for shipping to Singapore.​
* M's multi function Timer/Volt/Rpm/Shift Lights SOLD OUT!
Price RM169.00 Turbo Timer with Volt Measurement or Turbo Timer with RPM measurement. (Brand G'Zox)
Price RM239.00 Turbo Timer with Volt, RPM and mini shift light. (Brand M's)
http://i3.photobucket.com/albums/y88/ftzone/TTimer.jpg
Bro just 1Q this tt item no 1 from taiwan or..japan..tq.
free bump bro ..
Made in Japan
Updated News.
G'Zox is a Japanese Company. Therefore I believe this is a japanese products.
Only RM165.00. COD can be arranged at Butterworth / Seberang Jaya area.
The pix as promised. G'zox Turbo Timer/Volt Meter.
Manual timer can work from 10secs to 12mins.
-please check with your installer if it is compatible with your alarm system.
RPM,Shift Light & Volt
*thumbnail picture is volt reading.
warranty 7 Days againts manufacturing defects on all G'zox Multi Function Meters
im in sgor.. usually installation cost how much? if ur workshop charge how much?
depending on vehicle type & the alarm system used. typically installation charges are around RM30.00 - RM50.00
you can contact my bro wiramod11 012-2836068 (KL) he will guide u to his mech's place for installation.
hi
got pic...??
i m from BM....got include installation?????
PM me..
Hi, very intrested about is Timer, Price RM239.00 Turbo Timer with Volt, RPM and mini shift light. (Brand M's)
is the Timer still available?? i m from KL, is that free shipping to KL??
yes sir redline79. Free shipping to KL.. u just need to wait at home or office for the item to reach.. hehehehe :D gimme a call ok?
can be used with carb engine ka?
one more question which i would like to ask....cos i;'m very blur witht hese stuff....
i'm using carb-you say can be used
i want funtions like..
-off the engine with preset time-10sec,15 secs
-auto time for 0-100km./h? i think like pivot one?
-rpm/voltmeter?
which one had these funtions?
and where does the wire goes?
to the engine or? since it's a carb.//it's not connected to an ECU ?
can you please enlighten me
turbo timer can work on any type of car.
Engine speed I am not sure. Most new speed meters need to tap the signals from the ECU.
RPM meter can work with any engine whether its carb or fuel injection.
For carb the RPM signal is tapped from the ignition coil.
Hope that answer ur question. When wanna order? :D
Cheers.
does the rpm works accurately for 3 cyl engines?
sorry to be a little annoying..
i know it will work on 3 cyl..but does it support(as in accurately) for 3 cyl engines?you mentioned that it will work on 3,4 and 6 cyl meaning that there's a button that you can choose whether its 3,4 or 6 cyl?
I am very very interested with the Volt Meter with RPM measurement with shift light.
that is what i was refering to.
FYI, its going to be installed on a kancil 660 carb (no ecu)..there was no aftermarket tachometer that support 3 cyl engines until autogauge came out with one that can select to 3 cly with accurate readings..accurate as in it would be the same as the factory rpm reading..at least its not as bad as from a tacho that supports 4 or 6 cyl which is totally different...my main concern that it can be installed but its not accurate due to there's no switch to select..
so as long as yours has the switch to select on 3 cyl..i'm convinced and i'm placing the order right away..
pls advise..
letme check for u ok?
The autogauge RPM meter confirm suitable for your kancil. Price at RM98 only. It's your choice.
thanks dude..
i wouldn't want an autogauge meter..only interested with yours which is the Volt Meter with RPM measurement with shift light device because i want one which could read my rpm and volt..no others..
could you PM me when you have the confirmation?
thanks again!
