MSD product
deathzone
Kota Kinabalu
Im still using stock ek4 b16a distributor for my b16b 1800cc engine...is it safe or should i change to msd product? I know nothing much about MSD product anybody can suggest which msd item is suitable for me? Btw Im using this car for daily use but once in a while will rev it till 9000rpm.
if for daily use, just buy the msd blaster ss coil together with msd distributor cap, it will come with cable and rotor..
MSD SS Blaster coil at the side, MSD dizzy cap and MSD plug wires... Tat's my set up...
Here's the picture hot from the camera...
Blaster SS Coil Part No. 8207
Msd modified Honda distributor cap Part No.82922 or 82902
Super conductor wire set Part No.35349
Yes... Rev up faster 7500-9000...
Yes... No need worry internal stock coil suddenly kaput.
Yes... Look good.
Yes... Small hole in pocket.
Yes... Look good.
roughly how much should i be looking at? hehe.. need to see whether small or big hole for my pocket.
100% same setup, should be below rm1300.
Not sure current price. Did mine 2 years back.
oo, thats quite a deep hole for me. but looking at what its can do, its worth it.
If not more then rm1500 i will highly consider....just wanna ask which msd product come with launch control?
Search in their website. It is expensive.
Better of to get a chip with launch control or just get
Hondata S300j mounted into your Honda ecu.
Cheaper and more tuning option.
for B series... if ur already on OBD1 its about 2.5k siap pasang n tune for the S300
otherwise u have to convert to OBD1 ECU
if ur on K series... the K100 is also about 2XXX...
should be... if ur ECU is OBD1 it should be ok... can check hondata website for compatibility
check out this link:
http://www.preludepower.com/forums/showthread.php?t=314625
its from a prelude forum, might be the same but confirm with others first.
