MSD / ACCEL / Pro Comp Coil
Ck™
MSD Pro Power HVC Coil
Features
Designed for racing applications with an MSD 7 Series Ignition Control
Efficient E-core winding design produces more voltage and current
85:1 turns ratio and lower primary resistance produce high voltage output
Windings are encased in red epoxy and secured with extruded brackets
Spark plug style terminal and threaded brass primary studs
Supplied with rubber shock mounts
No CARB Exemption Order Number
Description
Coils have always had to compromise voltage output against current output. More voltage increases the initial ionization of the spark plug gap, but lowers the amount of current, or heat, that follows across the plug gap. When a coil is designed to produce more current, the voltage output generally suffers which taxes the ease of ionizing the gap. The MSD HVC Coils are designed to produce maximum voltage and energy! To accomplish this combination of high voltage and current MSD uses an E-core winding design. This is a very efficient design where less loss occurs during the transfer of electricity due to the closed core of the coil. Another benefit is that the coils run extremely cool, even at high racing rpm, thanks to the efficient design and huge laminations.
ACCEL Super Coil Ignition 45,000 Volts Universal
Description
Engineered for faster rise time, longer spark duration and increased performance. The Super Coil ignition coils unique design with premium grade wire, special low resistance, high turns ratio windings. Produces higher spark energy with breakerless electronic ignition systems. For points applications the supplied 0.85 Ohms ballast resistor must be used in conjunction with the vehicle's original ballast resistor, if so equipped. Oversized molded case with integral cooling fins and high capacity oil filled construction provide high thermal conductivity ensuring cool operation and long life. Extra tall tan Alkyd tower and integral voltage dam eliminate ''flashover'' to primary terminals. Comes complete with mounting hardware and 0.85 Ohms ballast resistor. Effective to 6,500 RPM.
Pro Comp Super Coil Max Voltage 42,000v
Description
Super Coil, Primary Resist 0.5 Ohms Secondary 9.6 k Ohms, Turn Ratio 75:1, Max Voltage 42000V
Higher Energy/Voltage Outputs
Improved Idle Quality
Optimized Low Resistance
Quicker Starts
Resists Corrosion
Resists Shock And Vibration
Silicon Magnetic Steel E-Core
Super Coil Ignition Coil
Procomp Super Coil Max Voltage 42,000V
*While Stock Last & Limited Stock*
**RM290** (MSD Pro Power HVC Coil)
**RM260** (ACCEL Super Coil Ignition 45,000 Volts Universal)
**RM220** (Pro Comp Super Coil Max Voltage 42,000v)
Serious Buyer Please Call / SMS
Contact : +6017 668 8171 -Ck
*Item Can Shipping To Any Where
*For Other Product Or Price Please Call For More Information.
