- MOTYLGEAR Oil 75W90
topsound
- 100% NEW in Bottle.
- Made in FRANCE.
- 1 bottle 1liter
- Genuine Motul OIL.
- Call us or walk-in to our showroom to get best price.
Buy from us, we are authorized MOTUL dealer.
We also have other type of Motul oil.
- Price excluding GST 6%.
TYPE OF USE
Specially recommended for gearboxes hard to shift and/or noisy gearboxes.
All mechanical transmission synchronised or not synchronised gearboxes, gearbox/differential, transfer gearbox and hypoid differentials without limited slip system operating under shocks, heavy loads andlow revolution speed or moderate loads and high revolution speed.
PERFORMANCES
STANDARDS API GL-5 and GL-4
MIL-L-2105D
Technosynthese® “Extreme Pressure” lubricant for an efficient anti-wear protection reinforced with
synthetic base stocks for a better resistance at high temperature and longer life time.
Stays in viscosity grade 90 after the KRL 20 hours shear test as requested by SAE J306 Standard.
Very high lubricating power which decreases friction and wear.Viscosity grade 90 at high temperature to provide outstanding oil film resistance at hot temperatureand/or to reduce transmission noise.Fluid at low temperature to allow easier gear shifting when the gearbox is cold.
Less effort required on the gear lever to shift the gears.Suitable for any type of seal and yellow material used in gearboxes design.
Anti-corrosion, Anti-foam.
Location : 22M,1st Floor, Jalan Pandan Indah 1/23A, 55100, Pandan Indah,KL (Look for Sign Board JASMA, above Trinity Pharmacy).
Payment option:
- Online Payment/Postage:
