Has anyone heard of a mivec engine that comes with a carburetor or modified
into that engine? I heard it from a fren that his fren modified his Satria Mivec
with this setup...
Well, it's actually my bosses' so called fren... he claims that this guy who is a mechanic can really mod a carburetor onto a mivec and get most hp out of it... my fren and I kinda think it's BS still like what you said, it has sensors to control the mivec system... but as usual... most bosses think they are right...
I think there is only one way can be mod... permanent switch to hi cam , then base on this to set the air fuel ... like class A car to changing all the vtec cam to single stage hi cam only ... to avoid vacuum time when hi low cam switching.
This year’s Tokyo Motor Show is the perfect opportunity for Mazda to introduce a RX-7 concept so there’s a possibility we may see it appear in October. The RX-7 will likely showcase Mazda’s new design philosophy...
Toyota aristo 2000/2002 V300 Black with lexus badging
2jz vvti twin turbo Vertex edition
Steering shift triptronic
Sunroof, leather , JBL full sound sys with amp and woofer...
any one intres to get Nishimiya San fr Quatermile Hi Perfomance Factory Japan and RH9 to tune or set yr Power FC,HKS F Con V pro or SZ,e manage or use NEKO Soft ware to remap yr oem ecu.....
he use apexi power...
