Mitsubishi Super Street Set up
hasbi_7
Hai... I am planning to let go my Mitsubishi Tredia 4G67 1.8 cc Turbo (1984) due to furthering my study to MBA (Master Business Admin). My car setting is super street race...
Engine (full balance) Spec are as follow:
Block 4G67 1.8cc stroke up to 2.0cc Evo 3rs.
Head port n polish to max
custom extractor
2wd Gearbox with ratio 4.6
Disk Break front and back with large rotor disk
# High cam 272 degree from Brain Crower and also BC valve spring (Add RM 2200 if want this high cam)
Optional Turbo (choose either one)
TD05 or/@
# A/r 60 (upgrade to high speed ball bearing turbo with Greedy spec - similar to TD06 Greedy) Fast spool... (Add RM 2400 if choose this turbo)
JPJ approved
SAFC D1 Immamura
Exedy 4 spoke clutch system
Custom Radiator (New)
Forge Radiator fans (New)
Oil Catch Tank
Oil Cooler
Metal Gasket
Wiring n comp box evo
Intercooler Evo 7 size
2 mercedes fuel pump
# Injector 750 cc RC high dependence (Add RM 950 for this injector) if not, injector will change back to standard.
Wastegate 1 bar spring
Throttle body S90
Interior:
Mono 3 spoke steering (ori)
Recaro seat (driver side only)
Passenger side Honda dc 2 (Will give also drive side)
Exterior:
Standart
front bumber change to Fiore
Adjustable suspension in front and 1tan lorry spring behind (to support the during speeding)
3 inch piping and "Kaki Motor" muffler.
Need paint for car to look nice...
Optional : Two 16" Rim with Toyo R888 tires (tires conditions 90%) for RM 800 (For sale separately)
RM 9,500 for standard setup, negotiable (without performance item like Turbo A/r 60, BC 272 cam, RC injector 750cc)
If include those 3 performance item, PRICE WILL BE RM 15,000, NEGOTIABLE A BIT....
CALL @ SMS: 019-6613488 (HASBI)
*the pic that i attach is quite old pic... Will upload new pic soon...
B.U.M.P.
Thanks RodneyEdwards...
What I sale here is for street race set up... I also have drag race set up engine... By calculation with the drag race set up, the engine can produce roughly around 600 to 700++ hp....
