Mazda RX-7
sakuraguy
5,000 RPM
Sendai, JAPAN.
Mazda RX-7
The Mazda RX-7 (also called the Savanna and Efini RX-7) was a sports car that began production in 1978. The original RX-7 competed in the affordable sports car segment with the likes of the Datsun/Nissan 280Z. The styling was inspired by the Lotus Elan 2+2. It featured a unique twin-rotor Wankel rotary engine and a sporty front-midship, rear wheel drive layout, making it well balanced and appropriate for racing. The RX-7 was a direct replacement for the RX-3 (both were sold in Japan as the Savanna) and subsequently replaced all other Mazda rotary cars with the exception of the Cosmo.
The RX-7 was a true sports coupe design, as opposed to a sports car like the Triumph TR6 or a sedan with sporting intentions. The relatively light Wankel engine was situated slightly behind the front axle. It was offered in America as a two-seat coupe, with four seats being optional in Japan, Australia, and other parts of the world.
The RX-7 made Car and Driver magazine's Ten Best list five times. In total, 811,634 RX-7s were produced.
http://img333.imageshack.us/img333/7927/safbqc4.jpg
Production: 1978–1984
Engine: 12A
13B-DEI (GSL-SE)
First generation
Series 1 (1979–1980) is referred to as the "SA22C". This series of RX-7 had exposed steel bumpers and a high-mounted license plate located in an indented part of the rear of the car, famously criticized by Werner Buhrer of Road & Track magazine as a "Baroque depression."
Series 2 (1981–1983) had smoothly integrated plastic-covered bumpers, wide black rubber body side moldings, wraparound taillights and updated engine control components. The GSL package provided optional 4-wheel disc brakes and clutch-type rear limited slip differential (LSD). The "FB" designation was only used in North America after the US Department of Transportation mandated 17 digit Vehicle Identification Numbers. Elsewhere in the world, the RX-7 kept the SA22C designation until the 1986 model year (second generation).
Series 3 (1984–1985) featured an updated lower front fascia and different instrument cluster (the S3 RX-7 is the only rotary-engined car to not have a centrally mounted tachometer). GSL package was continued into this series, but Mazda introduced the GSL-SE sub-model. The GSL-SE had a fuel injected 1.3 L 13B-RESI engine producing 135 hp (101 kW) and 135 lb-ft. GSL-SEs had much the same options as the GSL (clutch-type rear LSD and rear disc brakes), but the brake rotors were larger, allowing Mazda to use the more common lug nuts (versus bolts), and a new bolt pattern of 4x114.3 (4x4.5"). Also, they had upgraded suspension with stiffer springs and shocks, and a new, heavy duty oil cooler.
The 1984 RX-7 S has an estimated 29 highway miles per gallon/19 estimated miles per gallon. According to Mazda, its rotary engine, licensed by NSU-Wankel allowed the RX-7 S to accelerate from 0 to 50 in 6.3 seconds. Kelley Blue Book, in its January-February 1984 issue, noted that a 1981 RX-7 S retained 93.4% of its original sticker price.
The handling and acceleration of the car were noted to be of a high caliber for its day. This generation RX-7 had "live axle" 4-link rear suspension with Watts linkage, a 50/50 weight ratio, and weighed under 2600 lb. It was the lightest generation of RX-7 ever produced. 12A-powered models accelerated from 0–60 mph in 9.2 s, and turned 0.779 lateral Gs on a skidpad. The 12A engine produced 100 hp (75 kW) @ 6000 rpm, allowing the car to reach speeds of over 120 mph (190 km/h). Because of the smoothness inherent in the Wankel rotary engine, little vibration or harshness was experienced at high rpm, so a buzzer was fitted to the tachometer to warn the driver when the 7000 rpm redline was approaching.
Options and models varied from country to country. The gauge layout and interior styling in the Series 3 was only changed for North American versions. Additionally, North America was the only market to have offered the first generation RX-7 with the fuel injected 13B. A turbocharged (but non-intercooled) 12A engine was available for the top-end model of Series 3 in Japan.
Sales were strong, with a total of 474,565 first generation cars produced; 377,878 were sold in the United States alone. In 2004, Sports Car International named this car #7 on its list of Top Sports Cars of the 1970s. In 1983, the RX-7 would appear on Car and Driver magazine's Ten Best list for the first time.
http://img250.imageshack.us/img250/6341/fcqi1.jpg
Production: 1985–1991
Engine: 13B-VDEI
13B-Turbo (Turbo II)
Second generation
Series 4 (1986–1988) was available with a naturally aspirated, fuel-injected 13B-VDEI producing 146 hp (108 kW). An optional turbocharged model, known as the Turbo II, had 182 hp (141 kW).
Series 5 (1989–1992) featured updated styling and better engine management, as well as lighter rotors and a higher compression ratio, 9.7:1 for the naturally aspirated model, and 9.0:1 for the turbo model. The Turbo II moniker was dropped, and the turbocharged model was simply dubbed Turbo. The naturally aspirated Series 5 FC made 160 hp (119 kW), while the Series 5 Turbo made 200 hp (147 kW).
The second generation RX-7 ("FC", VIN begins JM1FC3 or JMZFC1), still known as the "Savanna RX-7" in Japan, featured a complete restyling reminiscent of the Porsche 944. While the SA22/FB was a purer sports car, the FC tended toward the softer sport-tourer trends of its day. Handling was much improved, with less of the oversteer tendencies of the FB. Steering was more precise, with rack and pinion steering replacing the old recirculating ball steering of the FB. Disc brakes also became standard, with some models (S4: GXL, GTU, Turbo II, Convertible; S5: GTUs, Turbo, Convertible) offering four-piston front brakes. The revised independent rear suspension incorporated special toe control hubs which were capable of introducing a limited degree of passive rear steering under cornering loads. The rear seats were optional in some models of the FC RX-7, but are not commonly found.
Though about 80 lb heavier and more isolated than its predecessor, the FC continued to win accolades from the press. The FC RX-7 was Motor Trend's Import Car of the Year for 1986, and the Turbo II was on Car and Driver magazine's Ten Best list for a second time in 1987.
In 1988, a convertible version started production in atmospheric and turbocharged form, proving an instant success. Despite production ceasing in October 1991, Mazda built a limited run of 500 convertibles for 1992 as "specials" for the domestic market only. In Japan, the United Kingdom, and other regions outside the US, a turbocharged version of the convertible was available.
In the Japanese market, only the turbo engine was available; the atmospheric version was allowed only as an export. This can be attributed to insurance companies penalising turbo cars (thus restricting potential sales). Overall, the second generation was the most successful for Mazda saleswise, with 86,000 units sold in 1986 for the US alone.
http://img333.imageshack.us/img333/1544/fdai3.jpg
Production: 1992–2002
Engine: 13B-REW
Third generation
Mazda Efini RX-7(1994) manufactured for japanese marketSeries 6 (1992–1995) was exported throughout the world and had the highest sales. In Japan, Mazda sold the RX-7 through its Efini brand as the Efini RX-7. Only the 1993–1995 model years were sold in the U.S. and Canada.
Series 7 (1996–1998) included minor changes to the car. Updates included a simplified vacuum routing manifold and a 16-bit ECU allowing for increased boost which netted an extra 10 hp. In Japan, the Series 7 RX-7 was marketed under the Mazda brand name. The Series 7 was also sold in Australia, New Zealand and the U.K. Series 7 RX-7s were produced only in right-hand-drive configuration.
Series 8 (January 1999– August 2002) was the final series, and was initially only available in the Australian and European markets. More efficient turbochargers were installed, while improved intercooling and radiator cooling was made possible by a revised frontal area. The seats, steering wheel, and front and rear lights were all changed. The rear wing was modified and gained adjustability. The top-of-the-line "Type RS" came equipped with a Bilstein suspension and 17" wheels as standard equipment. Power was officially claimed as 280 ps (276 hp, 208 kW) (with 330 N·m (243 ft·lbf) of torque) as per the maximum Japanese limit, though realistic power was more likely 220–230 kW (290–308 hp). The Type RZ version included all the features of the Type RS, but at a lighter weight. It also featured custom BBS wheels and a custom red racing themed interior. Further upgrades included a new 16-bit ECU and ABS system upgrades. The improved ABS system worked by braking differently on each wheel, allowing the car better turning during braking. The effective result made for safer driving for the average buyer. Easily the most collectible of all the RX-7s was the last 1,500 run-out specials. Dubbed the "Spirit R", they combined all the "extra" features Mazda had used on previous limited-run specials and all sold within days of being announced. They still command amazing prices on the Japanese used car scene years later.
-There are three kinds of "Spirit R"s: the "Spirit A", "Spirit B", and "Spirit C". The "Spirit A", which accounts for 1,000 of the 1,500 "Spirit" models produced, has a 5-speed manual transmission, and is said to have the best performance of the three models. The "Spirit B" is a four-seater, and sports a 5-speed manual transmission. "The Spirit C" is also a four-seater, but has a 4-speed automatic transmission.
The third and final generation of the RX-7, FD (with FD3S for the JDM and JM1FD for the USA VIN), was an outright, no-compromise sports car by Japanese standards. It featured an aerodynamic, futuristic-looking body design (a testament to its near 11-year lifespan). The 13B-REW was the first-ever mass-produced sequential twin-turbocharger system to export from Japan, boosting power to 255 hp (190 kW) in 1993 and finally 280 ps (276 hp, 208 kW, the Japanese manufacturers' gentlemen's agreement on engine power) by the time production ended in Japan in 2002.
The sequential twin turbocharged system was a very complex piece of engineering, developed with the aid of Hitachi and previously used on the domestic Cosmo series (JC Cosmo=90–95). The system was comprised of two small turbochargers, one to provide torque at low RPM. The 2nd unit was on standby until the upper half of the rpm range during full throttle acceleration. The first turbocharger provided 10 psi of boost from 1800 rpm, and the 2nd turbocharger was activated at 4000 rpm and also provided 10 psi (70 kPa). The changeover process was incredibly smooth, and provided linear acceleration and a very wide torque curve throughout the entire rev range.
Handling in the FD was regarded as world-class, and it is still regarded as being one of the finest handling and best balanced cars of all time. The continued use of the front-midship engine and drivetrain layout, combined with an equal front-rear weight distribution and low center of gravity made the FD a very competent car at the limits.
In North America, three models were offered; the "base", the touring, and the R models. The touring FD had a sunroof, leather seats, and a complex Bose Acoustic Wave system. The R (R1 in 1993 and R2 in 1994–95) models featured stiffer suspensions, an aerodynamics package, suede seats, and Z-rated tires.
Australia had a special high performance version of the RX-7 in 1995, dubbed the RX-7 SP. This model was developed as a homologated road-going version of the race car used in the 12hr endurance race held at Bathurst, New South Wales, beginning in 1991. An initial run of 25 were made, and later an extra 10 were built by Mazda due to demand. The RX-7 SP produced 204 kW (274 hp) and 357 N·m (263 ft·lbf) of torque, compared to 176 kW (236 hp) and 294 N·m (217 ft·lbf) on the standard version. Other changes included a race-inspired nose cone, race-proven rear wing, a 120 L fuel tank (as opposed to the 76 L tank in the standard car), a 4.3:1-ratio rear differential, 17 in diameter wheels, larger brake rotors and calipers. An improved intercooler, exhaust, and modified ECU were also included. Weight was reduced significantly with the aid of carbon fibre; a lightweight bonnet and seats were used to reduce weight to just 1218 kg (from 1310 kg). It was a serious road going race car that matched their rival Porsche 968CSRS for the final year Mazda officially entered. The formula paid off when the RX-7SP won the title, giving Mazda the winning trophy for a fourth straight year. A later special version, the Bathurst R, was released in 2001.
Racing
Racing versions of the first-generation RX-7 were entered at the prestigious 24 hours of Le Mans endurance race. The first outing for the car, equipped with a 13B engine, failed by less than one second to qualify in 1979. The next year, a 12A-engine car not only qualified, it placed 21st overall. That same car did not finish in 1981, along with two more 13B cars. Those two cars were back for 1982, with one 14th place finish and another DNF. The RX-7 Le Mans effort was replaced by the 717C prototype for 1983.
Mazda began racing RX-7s in the IMSA GTU series in 1979. That first year, RX-7s placed first and second at the 24 Hours of Daytona, and claimed the GTU series championship. The car continued winning, claiming the GTU championship seven years in a row. The RX-7 took the GTO championship ten years in a row from 1982. The RX-7 has won more IMSA races than any other car model.
The RX-7 also fared well at the Spa 24 Hours race. Three Savanna/RX-7s were entered in 1981 by Tom Walkinshaw Racing. After hours of battling with several BMW 530i and Ford Capri, the RX-7 driven by Pierre Dieudonné and Tom Walkinshaw won the event. Mazda had turned the tables on BMW, who had beaten Mazda's Familia Rotary to the podium eleven years earlier at the same event. TWR's prepared RX-7s also won the British Touring Car Championship in 1980 and 1981, driven by Win Percy.
Canadian/Australian touring car driver Allan Moffat was instrumental in bringing Mazda into the Australian touring car scene. Over a four year span beginning in 1981, Moffat took the Mazda RX-7 to victory in the 1983 Australian Touring Car Championship, as well as a trio of Bathurst 1000 podiums, in 1981 (3rd with Derek Bell), 1983 (second with Yoshima Katayama) and 1984 (third with former motorcycle champion Gregg Hansford). Australia's adoption of international Group A regulations, combined with Mazda's reluctance to homologate a Group A RX-7, ended Mazda's active participation in the touring car series at the end of the 1984 season.
The RX-7 even made an appearance in the World Rally Championship. The car finished 11th on its debut at the RAC Rally in Wales in 1981. Group B received much of the focus for the first part of the 1980s, but Mazda did manage to place third at the 1985 Acropolis Rally, and the Familia 4WD claimed the victory at Swedish Rally in both 1987 and 1989.
I wanna ask...
Is it possible to set a time from Tuas Toll to Sungei Besi Toll in 1hr 13mins???
why not dude? It is possible if powered by 3 Rotors.................
on an airplane wankel engine :_: hehhee...
But honestly I know there is a ferrari spents 45mins from sg besi toll to malacca just before the sun rises in the morning :mouth_closed: !
Bare with me for awhile, I will explain to you guys why i am asking this question later...
The Car Setup:
1. Savanna Chassis 84 Turbo Edition
2. Converted to 13BT Street Ported Mark 4 Engine
3. FC Mark 5 Turbo
4. FC Mark 5 Intercooler
5. Racing Beat LSD
6. Microtech D5 Aftermarket ECU
7. Cosmo Gearbox
8. Standard 3.9 Final Drive
9. Full Body Kit ( Not Wide Bodied yet)
10. 15 Inch Rims
11. Tyres (Front 205/50/15 & Rear 225/50/15)
12. 2.5 Inch Piping
13. HKS Super Dragger Exhaust
14. K & N Open Pod Filter
15. Basic Sound System (1 4Channel Amp)
16. Boost Level at 1.0 Bar - 1.3 Bar
17. Racing Beat Springs
18. Greddy Adjustable Shocks F/R
Total Distance to Travel is approximately 350KM. Time to reach destination = 1hr 13mins. (Inclusive of Toll). The car has to be strictly a 13BT not a 20B Engine. No pit stops!!!
not possible la.....
with the setup....
bunch of northern folks going down to KL with supras, GTR, FD... they going at averaged speed of 200 km/h...
they made it at 2hours.. that's what i heard from them... KM is around 350 km also....
so.. you're saying.. 1 hour 13 mins..... this wil be rev like FUCK.... and impossible can make it 350 KM with one tank of gas....
going at 240 km/h.... around 6000 rpm... not possible....without re-filling the petrol...
Alchemis...
Forgot to tell you...
The Cosmo Gearbox matched with the 13BT has an amazing Long Ratio, even when you reach KL theres still fuel in the car.
Somebody has done it at 1hr 13mins...
IMHO...
The Rotary is an amazing Engine, City driving FC is high, but on Highways, the FC ain't that high especially at higher RPMs, unless injectors have been upgraded extensively.
Theres a BET on with a Non-Rotary Car... Winner takes all!!!
hmmm, i think i know who you're talking about...
does he and powerboats have something in common?
Wow.... means constantly the car is travelling about 300km/h!!!! darn!!!!!
The Car Setup:
3. FC Mark 5 Turbo
5. Racing Beat LSD
7. Cosmo Gearbox
10. 15 Inch Rims
12. 2.5 Inch Piping
Technically it would'nt be possible, unless the Gear Ratios are worked out properly, plus 2 tolls to cross.
A couple shots of NOS... maybe its possible...
I reckon the best time would be still 2hr 13mins...
Any mistake at the speed of 300km/h = huhuhuhu!!!
Just wondering has anybody done within the 1HR ++ time frame in ZTH???
Totally impossible..... Even it's a clear road, you have bends to slow you down....... Secondly you need at less 150 liter of fuel tank to do so...... Then you need Superman's mind set to keep yourself concentrate..... Do you know that you can pass out doing 300 constantly?? Even the Daijiro Inada who enter the SIlver State race can ony manage an average speed of 269KPH...... Clear road with slightest bend.......
1 hour 45 more realistic to me.......
but i remember i done 2 hour 40 before....... Now i'm kinda fuzzy now....... Constant 160KPH-180KPH that time.....
Lennon...
Thank you for the advice...
If fact thank you all for your advice...
I also realised now that realistic time would be 1hr 45mins to 2hr 15mins.
So it wouldnt be possible also, because of the traffic regardless of time. Short burst up to 2++ km/h would be possible, but to maintain top speed at a consistant period wouldnt be possible (that I have to agree).
But honestly, my previous RX7 broke so many gearboxes, so finally my mechanic found me one that lasted. It was the "cosmo gearbox". The first day they managed to remove the broken gearbox and replaced the cosmo gearbox into the rx7. But the funny part was, the gear lever had this amazing long stick, it stuck out like a sore thumb (30cm high). I complained about it, and my bloody mechanic said, "NO time lar, u drive first... tomolo come back, I settle for you". So I had to live with the F^$^ing Ugly Stick for 1 night. I had troudble shifting as I had never used such a long lever before, but finally a night passed. Next day, first thing in the morning, went back to my workshop, they grinded the bloody long stick into half and custom welded it together.
Finally it was back to norm... tested it, and tot to myself... not bad... short throw too!!! I liked it, bocs of the custom angle and height.
Went for a test drive, didnt think too much of it at first, but i realised, when u pull it will take some time to finish as the ratios are longer. But as for top speed you can guess...
kelfo .. can share some of ure rides? ... please post at "Your Shots" section .. it maybe impressive to see such Malaysian tuned cars.
Cheers!
