Mazda BT-50
Mazda BT-50
steven7810
mivec user
kuala lumpur
Hello to all mazda fans.... The brand new mazda bt50 will be in malaysia on this coming april 2012...
I will update you all once i got the spec and price....
From steven 017-2392780...
Hello... The brand new Mazda BT-50 estimated in July or August..
I will updated you all once I got the information...
Update update The New Mazda BT50 is coming soon.. Now pending approval from Gorverment department.. Once i got the detail in price,spec and color i will update again...
Steven 0172392780
Thank you...
Hello....Great News......
The Brand New Mazda BT50..2012
Price List.. For 2.2 MT RM 89,841.60 for Personal use
Price List.. For 2.2 MT RM 90,244.80 for Company use
Price List.. For 2.2 AT RM 95,552.60 for Personal Use
Price List.. For 2.2 AT RM 95,965.15 for Company Use
Price List.. For 3.2 AT RM 107,051.75 For Personal Use
Price List.. for 3.2 AT RM 107,483.25 For Company Use..
Thank You...
Steven 0172392780...
Hello...Update the Mazda BT-50 2012 CBU..
2.2L Auto or Manual 4x4
Engine Spec : I4,DOHC,16,Turbo Diesel
CC : 2198
Max Output : 150HP/3,700RPM
Max Torque : 375Nm/1,500-2,500RPM
Fuel System : Commonrail Electronic Direct Injection
Fuel Tank. : 80 litre
Steering Type: Rack and Pinion Power Assisted Steering Wheel (Engine REV sensing)
Transmission : 6MT-LSD or 6AT
Suspension : Type FRONT : Independent Suspension
Type REAR : Double Wishbone with Coil Spring/Rgid,Leaf Springs
Brakes. : Ventilated Disc. Rear Drum Brake.
Tyre Size. : 265/65/R17 with Alloy Rim 17x7.5J
Over Length. : 5365mm
Overall Width : 1,850mm
Overall Height. : 1,821mm
WheelBase. : 3,220mm
Minimum Ground Clearance : 237mm
Maximum Kerb Weight. : 2,091kg MT and 2,011kg AT
Acc :
Rain Sensor Auto Wiper
Electrically Controlled Remote Foldable Side Mirror with Turn Signal Light
Power Window with Anti Pinch System ( Driver Side Only)
Dual Zone Fully Auto Air Cond
Leather Wrapped Steering Wheel with Audio Switched
Halogen Headlamp with Auto on/off
Dot Matrix Audio Display : CD,MP3,AM/FM,USB and AUX(6 Speaker Sound System)
Bluetooth HandsFree System with Voice Command
Safety
4W-ABS with Dynamic Stability Control (DSC)
Hill Descent Control (HDC)
Traction Control System
Driver's and Passenger's Fromt Air Bags
Call Steven 0172392780 OPEN FOR BOOKING
---------- Post added at 05:14 PM ---------- 6 hour anti-bump limit - Previous post was at 05:10 PM ----------
Mazda BT-50 2012
Engine
3.2 I5 DOHC,20V,Turbo Diesel
CC : 3,198
Maximum OutPut : 200HP/3,000RPM
Maximum Torque : 470Nm/1,750-2,500RPM
Transmission : 6AT only
Spec as above 2.2
OPEN FOR BOOKING
STEVEN 0172392780
---------- Post added at 05:14 PM ---------- 6 hour anti-bump limit - Previous post was at 05:14 PM ----------
Mazda BT-50 2012
Engine
CC : 3,198
Spec as above 2.2
OPEN FOR BOOKING
STEVEN 0172392780
open for booking
call steven 017-2392780[/b]
Hello..good morning... keep In Touch.. Will update more detail...
open For Booking
Call Steven if interested to view the actual car...
Open For Booking..
Steven 0172392780
