LUCAS SUPER COOLANT.
Lucas Super Coolant has been scientifically formulated to provide the ultimate protection in automotive and racing cooling systems. It protects the entire system from rust, corrosion and electrolysis including aluminum.
Our unique formula prevents deposits that can cause overheating, and has been proven to reduce coolant temperatures up to 20°F.
Lower cylinder head temperatures means advanced ignition and more horsepower.
BENEFITS
Lower cylinder head temps
Allow advanced ignition, timing and more horsepower
Reduce operating temperatures by up to 20°
Prevents corrosion, electrolytes and deposits that cause leaks, overheating, and cooling system failures
DOSAGE
For street vehicles requiring freeze protection, add 1 bottle to 50/50 mix. For racing and high performance applications, add 2 bottles to straight water coolant for maximum temperature reduction.
One bottle treats 12-20 quarts of a 50/50 water antifreeze mix. Two bottles are required for straight water coolant. For passenger cars, light trucks and SUV's use every 30,000 miles. For racing applications use every race as needed.
DIRECTIONS
With engine off and cool, shake bottle and pour into radiator. Start engine, turn heat on high and run for 10-15 minutes to circulate through entire cooling system. If straight water coolant is used, tap water or softened water is recommended. DO NOT use distilled water unless mixed with 50% antifreeze.
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Operation Hours: Mon~Sat 9am~7pm
GPS: Latitude 3.067118, Longitude 101.601951
Click Here For Google MAP Location
Land Mark:
Same row with Kedai Tayar Silverstone Teck Meng, REV PERFORMANCE, Millennium, 2 shops beside SAMURAI RACING.
For serious buyer please Whatsapp or SMS
Desmond 017-396 8567
Email us : [email protected]
Dealing method : Pos/Courier everywhere in
Malaysia including Sabah, Sarawak, Brunei, Indonesia, Thailand, Singapore and all area in Asian.
BENEFITS
DOSAGE
DIRECTIONS
Bdr Sunway.
47500 Subang Jaya.
Land Mark:
