lokking for buyer....for 4g91 engine set..
ijoe
im looking for a buye for my 4g91 item
4g91 head..
4g91 manual gear box...
4g91 manual wiring...
4g91 manual ecu...
4g92 high compression piston with new ring & bearing...
54mm throtle body...
4g91 ported intake manifold...
what else arr..??? i think all d 4g91 engine set except block la....
anyone intrested PM me or sms me at 019-6076246....engine are superb....u can try i before dismantle all of it...so far can get it for 113HP on wheel & 130++ hp on crank...i raly take car of all this engine part....
curious... sorry for being blur. can your 4G91 manual gear box be fitted onto my 4G13 Proton Saga (1987)?
Bro, im very keen here. Where is your location, or where can we meet? Also, whats your price for the set anyways? Pls reply bro,
Interested with ur 4g91 wiring & ecu. How much to letgo? PM me the price.thx
jeyadev curious...
i heard i can be done...but let me check it up first later will let u know...if can then u want arr??
so far willing to let it go all d item.... not part by part... easy for peopple to upgrade dia engine without changing block ...no need 2 register la...
will let it all go for 2.5K nego....u will get all accept block....coz me also dont want 2 re register maa....he...he...he...leceh....
so far i prefer all d item goes off one shot...my location is Shell bandar tasik selatan or u can meet me tmorow nite at esso, sunway pyramid...or makro cheras....or Tabung haji building jalan tun razak....just call me for arrangement
my hp 019-6076246 (ijoe)
gear box
4g91 head..
4g91 manual ecu...
hello interest with your 4g91 gear box.is that you will give me the drive shalf and clutch pump.pm me your best price
so far...i nak let go sekali gus...btw...tengoklah nannti ..kalau banyak permintaan utuk seprate item..myb aku akan jual separate item...mine gearbox is clutch pump...but let me check mine future concersion item first...planning masuk this saturday...so sape yang nak test kete aku sebelum aku dismantle kan ...u r welcome...if u wish to buy la...he..he...call me ya...
ijoe... tak tau lagi, kalau boleh masuk Saga biru aku ni, aku rasa engkau jual kat choonteck la, cos he already confirmed that his car can fit it :)
choonteck...
if u take all...4 my gearbox yes... u will get clutch pump also...for that clutch pump i just change both bottom 1 & upper 1 for a new 1...tak sampai 1 bulan aku baru tukar...& i tukar baik punya ..not low ya punya..coz nak pakai sendiri kan...dont want problem la....so luckly if u get this......but no drive shaft...taht 1 cheap only....
most of my item are new part...already replace for good quality...supposed i will give u the piston with the crank also.....high compression....new also...no need to change anything....if u get my engine set...no need to do major job...just put in yr block & setting & run...i think if u want i will give u fly wheel also...but for that i will check it up first..do i still need for my old fly wheel...or just used my new fly wheel on my new gearbox....if not i will give u that also...will give u timing belt...new distributor..just change ....1.8 TB...if u need i can give u 1.8 extractor also...
supposed everything i have la...except block only...
so hows bro..tday taht car will going to workshop already for trasplant...but i can give my word la..the set are very nice...u can ask most of 4g91 geng..about my engine if u want...
if u want beeter response...just buy a few buck of 1.8 soch block then put all my engine set...then pergh...u will feel d power...
let me know bro..
bro, ur 4g91 ecu wat code ar bro? if #1234 i want it, but if #5560/#7375 i want ecu + wiring how much ur price? pm me....
ur gbox 5th gear @ 3k rpm running how many Km/h?
my ecu is 1234....
my 5th gear! i cant remember..but think 3k at 110-120...round that la...i check first....aiyaa...so many people only want part by part ar....dont want lump sum arr..ok la..let me convert my engine first...see what are left...then i have all yr nick..later i cantact u all ...i think conversion will finish in 5 days...let u know then...ok all geng...
ijoe said:
my ecu is 1234....
hmmm..1234 good, if possible u sell ecu onli please pm me the best price bro..cheers:regular_smile:
bro can the throttle body to be fit in 4G15 engine year 1996.if so i'm interested
allo bro, how u upgrade ur 4g91 kasi power? i used that engine osso, but cannot going laa bro..
any one can help me??
alonso...
in case ijoe is not selling saperatly his ecu..
i got 1 full set 4g91 5660 wiring and ecu letting go cheap..
coz i upgraded my ecu n wirng already
gear box
hi,brother actually i just interest on your gearbox.because i already convert my car to 4g91 engine,just because last time want to save cost then only use back my wira original gear box,but after convert i fell that the gearbox not match with my engine and somemore fuel consume.and now the gearbox give me a min or problem.now planning to change the gearbox.if u can sell seprate then good new for me lah.pm me if u want to sell seprate.:_:
bro..how bout your distributor??if u want to let go pls pm me...serious buyer here
Yong_5290 said:
alonso...
can you pm me your best price...
