kelisa bolt on turbo using emanage
snopp
pj
to all master,
im planning to bolt on my car also plan to use emanage.pls advise what is good and wat is bad when i use emanage..thanks.i need opinion here.hope u all can help.
u planning to bolt on stock engine right?? as wad i know e-manage doesnt support 3 cyl engine.. correct me if i'm really wrong! :P
cheers
if i m not mistaken e-manage doesnt support 3 cylinder... go for haltech...
snopp,
u might wanna try OBIT instead...price is around the same, including all the harnesses and stuff...
kelisaSnail said:
e-manage dunt support 3 cly ah? is this confirmed?
if e-manage does support EJ-DE i think most of kenari/kelisa user will go for it instead of SAFC..
or if u love ur car very very much den u can consider getting a stand alone ecu..
my 2 cents..
i also dunno...but according to my mec he said can be done.bolt on not as good as convert but i change the piston also.make the compresion as low as possible. compression normal kelisa 10..higher than vtec.but if i can get around 8 than i wil able to boost at 1 bar.but where can i get OBIT?
kelisaSnail said:
Hmmm... but some pple say can be installed leh... confused.
boosting at 1.0bar? r u sure? bolt-on oso can boost so high?
1 bar is the max..but to play safe .8 wil enough.provided u tune ur car nicely..that y i need information on the ecu.so that i can retard the timing also to fine tune it.
you could contact Andy (0123963348) of Dragger Racing, they are the autorised dealer/tuner for OBIT..they've done kelisa bolt-on turbo with OBIT...
a few kelisa's...just dunno where they're hiding only...hehe
i wouldnt recommend AFC for your setup...the afc adjusts according to rpm levels...not boost levels...
bolt on
bro , where to get bolt on turbo for kelisa ?
and what else have to be change if i fix it ?
how much will it cost?
hi kanna,
bolt on kit can be done using l9 turbo kit. cost also depend.if u interested then
call me..
snopp said:
hi kanna,
call me..
i really interester but it also depents on the cost u see ... so if u could tell me
around how much so i can plan some thing out some more i planing to
upgrade my car performance ..... I am still a student so see la and i have one
month break so it would be nice time to get an upgrade
the cost i also dunno as i said it depend.better you find a mec that u know then ask.so mayb we can hang out n discuss how to upgrade our car..
