K-TUNED Water Pump Complete Kit
powerautohauz
Part Number KWP-PKFJ-204
Here is another innovative part from K-Tuned. For several years now racers have used electric water pumps to reduce the power robbing effects of parasitic drag from their engines. By reducing the number of accessories the crank needs to turn there can be some impressive gains. The K-Tuned Water Pump Block Off Plate system was designed to setup a K-series engine to run an electric water pump cooling system. It replaces all the bulky and heavy OEM accessories with a simple lightweight aluminum plate. The kit is designed to allow the perfect flow of coolant and also effectively release unwanted crankcase pressure. The water port is sealed just like it was from the factory using the oem o-ring seal. The breather port is threaded for an 8AN fitting and can easily be routed to any catch can set-up.
We have also designed an alternator bracket setup to be used with lighter Honda B and D alternators. The 01-05 EM2 alternator is perfect to use with this kit because it will plug in directly to the K-series engine harness. The EM2 alternators are also pretty easy to get and generally they aren’t too expensive either. We have put together a series of kits allowing you to choose which parts you want, so you can build a system that works perfectly for your application. This is a must have for serious race car builds and a true favorite among All Motor racers.
Key Features:
- Replaces the huge oem water passage with a lightweight block-off plate
- Deletes oem water pump, auto tensioner, P/S, A/C and EP3 pulley
- Alternator mounting bracket available with most kits
- Belt and fittings available on some kits
- Electric water pump and pump fittings available with complete kit
- Designed to be used with lighter D series alternators (01-05 EM2 Civic Alt. is a drirect fit)
- CNC machined 6061 aluminum
- Large coolant port is tapped for 3/4” NPT thread
Smaller Breather port is tapped for 8AN (3/4 – 16 SAE) thread
*Note, water pump provides 20 gallons per minute flow rating
Complete Water Plate Kit Includes:
- Water pump block-off plate
- 4 mounting bolts
- Alternator Mount kit
- Alternator Belt
- 12AN 90 degree Water outlet fitting
- 8AN breather port fitting
- 2x -12AN 90 degree fitting
- 2 feet of -12AN braided coolant line
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Operation Hours: Mon~Sat 9am~7pm
GPS: Latitude 3.067118, Longitude 101.601951
Click Here For Google MAP Location
Land Mark:
Same row with Kedai Tayar Silverstone Teck Meng, REV PERFORMANCE, Millennium, 2 shops beside SAMURAI RACING.
For serious buyer please Whatsapp or SMS
Desmond 017-396 8567
Email us : [email protected]
Dealing method : Pos/Courier everywhere in
Malaysia including Sabah, Sarawak, Brunei, Indonesia, Thailand, Singapore and all area in Asian.
