Is the Extended spacer reliable????
jgv5383
Ipoh
Hi all guys and si fu,
do you guys try to plug in any spacer for your car??
if yes then do you guys experience the problem after u guys install it??
any side effect??especially at hi -speed???
need your help!!!
thanks..
nope...cos wanna fit in the evo body kit,so have to make it wider..
is it ok that i add tat spcer?
any side effect?
just worry of that...
my wira got spacer, seems to affect the turning radius
need more space to u-turn
like tat?err..if i add 1.5 inch then shouldn't be a big prob,rite?
then will ur car feeling not so comfortable?
when u add spacer your car balancing will be effected..the tyre shop will be having problem balancing your tyre if u get the spacer that is not level with the tyre....
FWD cars are designed to have wider front track for good handling where RWD cars have wider rear tracks.
when you install spacer to make rear tracks wider than the fronts, as Sta mentioned will affect turning radius.
doing so will only improve car looks and remember that Evos are 4WD cars.
a spacer so thick also may not allow tyre bolts to lock the wheels securely.
my lowered car is so bumpy especially at the rear
where can i get a "spacer" to make my car a bit higher ?
