huster audio tube amplifier AR75.2
ICE -In Car Entertainment
interfires
terengganu
The Hustler amplifier distinguish itself world-wide as they have been engineered after much research and study of the world™s top notch hybrid amplifiers, their strengths™ and particularly their weaknesses™, thus, producing a product line of the highest performance level. With matched 6N9P Twin Triodes tubes applied, Hustler Audio™s Hybrid amplifier has a warm golden tonality designed as a top-range, hi-fi systems, output stage amplifier where sound quality is indeed the primary objective. The components have been upgraded as its sound effect is coupled with a felt vibe of the music, courtesy of its prominently researched, new age technology and are currently available together now in the new Blockbuster:
The AR 75.2
Features
Open Ended Audiophile Circuitry
Zero negative feedback
Regulated Tube Heaters with 15sec Delayed Soft Start
6N9P Twin Triode tubes
Warm, musical and dynamic
Regulated Mosfet Power Supply
Short Circuit Protection Circuitry
Dual Color indicative LED: Green=Normal / Red=Fault
Specifications
Rated Power (All channels driven)
Rated Power (all channels driven):
- 2 x 75 Watts RMS per channel @ 4 ohms
- 1 x 300 Watts RMS Bridged (Mono) @ 4 ohms
2-Ohm Stereo, 4-Ohm Mono Stable
Freq response: 5Hz to 50kHz (+/- 1dB)
THD: S/N Ratio: >110dB (A-Weighted)
Idling Current: 1.7 Amps
Input Sensitivity: .450v - 12v RMS
Fuses: 1×30A ATC
Dimensions: 310 L x 240 W x 80 D (mm)
Weight: 8 Lbs.
sell coz upgrading
rm500 each
location kota bharu.
call/whatsapp 0196420395
