How to Differentiate Between Evo 1 and Evo 3 engine?
xerofighter
Not so senior member
Subang
i need to find out how to diffrentiate between evo 1 and evo 3 engine? lets say its an evo 1 but the prevous owner upgraded the intercooler and all to make it look like evo 3, how to tell? got any number on the engine? the ap is not reliable so cant depend on it.
thanks.
engine is all same 4G63 series. on EVO 1 to 3 the timing belt is on the left side (same like wira) but beginning EVO 4 to present it is reversed (like Waja).
not much difference on the looks.... very similar. only power output differs.
VR4 1988 200bhp
EVO 1 220bhp
EVO 2 250bhp
EVO 3 280bhp (restricted)
EVO 4-8 280bhp (restricted)
except EVO 8 FQ330 has 330bhp (made by Ralliart UK).
should ask at Mitsubishi sifus at the forum.
i wonder y u asked and abt to answer , until my bro (2nd) and told me abt it..damn it...
VR4 1988 200bhp
EVO 1 220bhp
EVO 2 250bhp
walau now I know EVO3 is restricted to 280bhp (got this high HP:confused: )
it is an agreement between the authorites in Japan to resrict it. same goes to Subaru Impreza (also 280bhp) although we know there are more powerful versions especialy in the UK.
want to know why all Japanese cars have 180km/h max speedometer? part of the understanding laa....
and in most of the cars too... buzzer warning once they reach 105km/h to warn the driver thay are exceeding 100km/h.
ha ha ha ha sighh....
Evo I - 250hp CD9A 1992 Oct
Evo II - 260hp CD9A 1994 Jan
EvoIII - 276hp CE9A 1995 Feb
hopes this will help u out
may i know wat is cd and ce..
thanks
I hope this help u:
How to differentiate EVO 1/2/3?
Check the body code:
EVO 1 --CD9A-SNGF
EVO 2 - CE9A-SNGF
EVO 3 - CE9A-SNGF
EVO 1,2 turbo no. 49178 0145
EVO 3 turbo no 49178 0147
EVO 1 and 2 : intercooler size r same
EVO 3 : intercooler bigger than EV0 1/2
EVO 1,2,3 ECU number 7701 (all same)
EVO 1
1992
MITSUBISHI LANCER CD9A
Engine: 4G63 (2000 cc, I-4, Turbo 250 hp)
Layout: Front / 4WD
EVO 2
1994
MITSUBISHI LANCER CE9A
Engine: 4G63 (2000 cc, I-4, Turbo 260-270 hp)
Layout: Front / 4WD
EVO 3
1995
Layout: Front / 4WD
U can also check
1) Engine head code beside distributor.
EVO1 - G6K - 1 or 2
EVO 2 - G6K - 3
EVO 3 - G6K - 4 or 5
2) turbo
EVO 1 - 45
EVO 2 - 46
EVO 3 - 47
3) ECU code
E1 - 7701
E2 - 2468
E3 - 2364
4) Piston ( if engine dismantle)
EVO1 - H1
EVO2 - H2
EVO3 – EV
* Most manufacturer rate the power on engine ( it read more horsie - good
marketing)...expect 20-30hp loss on wheels. Bear in mind, that the HP
also loss to transmission around 10% - 15% for 2WD and 20% - 25% for four
wheels drive. This is the norms at least for Mitsubishi engine.
crocky said:
I hope this help u:
EVO 1 --CD9A-SNGF
EVO 2 - CE9A-SNGF
EVO 3 - CE9A-SNGF
EVO 1
1992
Layout: Front / 4WD
EVO 2
1994
Layout: Front / 4WD
EVO 3
1995
Layout: Front / 4WD
U can also check
EVO1 - G6K - 1 or 2
EVO 2 - G6K - 3
2) turbo
EVO 1 - 45
EVO 2 - 46
EVO 3 - 47
3) ECU code
E1 - 7701
E2 - 2468
E3 - 2364
EVO1 - H1
EVO2 - H2
EVO3 – EV
thanks everyone for your quick response. and this message really helped me a lot. i will check and get back to you guys. thanks again
huakenny said:
tat mean d engine performance can go higher if not restrict???
probably. evo 4.5.6 all have built in anti lag system but was disabled in the road going version.
hey read up this site...pdf files..you can even save it...it tell all about
mits EVO cars .... :D hope that helps out...
http://www.lancerregister.com/mlr_images/articles/evobuyersguide/buyers_v3.1.pdf
wah crocky..so detail one. thanx and respect laa...
anyway, standard EVo even though has 'on paper' 280bhp but there were 2 upgraded versions in UK sold officially by Ralliart UK.
1st is Evo7 FQ330...330bhp
2nd is Evo8 FQ400...u guessed it rite...400bhp.
there is more then 2 upgraded versions. they give a lot pf package depending on the budget.
