Honda Civic EK3 suspension prob, plz help
Lesley Fung
From Facebook
Kota Kinabalu
My car is Civic EK3
The problem is got abnormal sound at from arm then
1. At 1st, I changed all ball joint and the noise still same
2. Few months later, I changes upper arm bush and the sound reduced 50%
3. Few months later, I change lower arm bush and the car run steady with new bush but the problem is the noise increased
what will the problem be?it is
1. Absorber??? --->my absorber no leaking or the absorber bush damaged??? --->is this bush sold in market?
2. Absorber shaft worn out???
please help me, the sound is getting higher, it is annoying :bawling::bawling:
sound is the headache issue to diagnose/check
its hard to discuss over forum as hard to describe the sound.....better sent to shop to check
Lesley, you can refer to this thread (post#135). I had the same problem as yours a few months ago, now it's been solved already.. :proud: I drive an SO4, but the suspension is the same as your EK3.
