Hks F-con
Need Help On Installing HKS PFC F-CON
was asking tis on behalf my fren...
the thing call as "HKS Electronic Technology , PFC F-CON , HKS Programmed Fuel Computer System"..i am not so sure wat was tat yet cause i not yet see on the item..he just called me and ask whether me or anyone out here know how to install tis..
He is using 4age engine...
and the problem he having after installing the thing is he cannot start the car...
if any brothers or sisters out there know how to fix the problem kindly reply to my post...thanks in advance!!!
this thing.. blardy hate it... bought a set for my bro's ca18....it came together with d gcc, harness ,fcd,boost sensor and boost meter..plug it in ... the car was able to start... only when i try to install boost sensor...farked up the pfc..got smoke came out... car cant start...keep cranking... notice petrol smell... found out tat fuel coming out frm exhaust.....keep checking only to found out when i on engine injectors spraying liao...untill fuel pump hose no preassure...now sent to repair.. duno can repair or not .. one of the IC bengkak liao...im reli no expert... tats y im facing tis.. find some one experience to do it for u.. tey have all d answers that u need
AT present, N1 is authorize dealer of HKS, including the F-con managements and the unlocking key.
n1 alr called, dey dun do f con s, n older versions...!!! onli latest wans...!!!
try aerotech.they used to sell n tune hks f-con.
they r the first hks distributor in m'sia.
i saw a 2nd hand item fcon vpro with harness for evo123,izit possible to fix it in vr4?
Renxun,my fren have same problem like your bro, got no smoke coming out,but did have problem like you mention,injector keep spraying, dunno how he fix it,4age engine
wahhhh so many probs ar, like dat rather use safc lo... hmmm guys ur idling how? got unstable ar?
one of the ic inside the pfc was swell up ... so i just send it to my fren to fix it... tats b4 CNY.... havent got any news from it... the reason why it spoil is bcuz the electronic boost meter came together with boost sensor which i thought tat is d air flow convert to map sensor... i never notice the boost meter was a electronic one untill i take out and says "shit" as i thought it was mechanical meter....so when i wire the thing up the whole thing smoke up my whole car... hope it can be fix la..
den after installin it, does ur idle screw up? i mean not consistent....
Aerotech now more on servicing and selling Dynojet dynanometer, getting lesser on tuning and car modding biz.
Heard they going to intro new engine management system from US.
Currently, this new management system being tested on superbikes locally.
tuned alr at TRIAL.... pretty impressive, esp da tuner, from how i c it, hmmm he does it wif perfection, wat ever prob u hav in ur car, he'll try to figure it out, wats da cause... THUMBS up, so far so gud ler... at least beyond my expectation...
will c how da car goes... :) to earli to judge now...
im having some issue, where after a week, the 3rd plug from front, kept flooded by fuel.... i've alr replaced da injectors, n da injectors seems to b workin fine...!!!
prior to dis, da plugs im usign for my rb20det, is platinum ngk no 6 plugs... works for OEM rb20
does anybody noe by changing to iriway no 8 plugs will help my fuel combustion instead of flooding at the 3rd plug???
bro..how much does it takes fr u to tune in TRIAL?
I wanted to buy f-con v n is fr chop shop. can they unblocked the f-con v?
f con v? da old version ar??? i asked b4... cannot... jus road tune 600 i think
GTi GSR
FCON V is newer than FCON S and FCON V is upgradeable to FCON V PRO as well
