guys currently im having prob, when i press the clutch, the wheel area has a cliking sound.. only when when the car is moving and when clutch is in.. anyidea what could be the prob..? pls help...
today i realise the sound is there even when driving but not so noticible unless press clutch pedal.. and the sound is from driver side.. i check under the car i saw my drive shaft cover bocor and the grease is pouring out.. could this be the cause of the sound? how much to change the cover and put the grease..
hey man, today i found out that i need new brake pads... any idea how much ori toyota ones? anything better than ori one..? using ae101 single pot.. thanks dude
This is just kind of a survey. Just state your maximum price and your reasons. Also if you willing to make exceptions in certain cases like special or rare models or you love those certain rims.
Hi all situ,
Currently I'm on 17" rims with 14kg each. Thinking of upgrade to 18" rims with lighter weight, say around 10 kg each. How would it fares in terms of ride comfort and fuel consumption?
