hey every sifu
wht hardest piston for B20B
The JUN Super piston kit is manufactured by Cosworth Racing in Britain. They are designed for corresponding to high boost, high rotation and high response. This is produce by reducing blow-by gas as well as boosting response up. The material use this piton is special aluminum for forging use with a 400t manufacturing press into the mould. The Durability is excellent.
robokopf said:don't mind if i chap in,
isn't those JUN Super Piston Kits manufactured by Cosworth?
http://www.innovateperformance.com/jun/images/products/cyl-block-Super-Piston-Kit.html
KAY 3333 said:is it je hard enough??
if stock 1.8 piston hard eng??
any other model stock piston?
J101 said:hard in terms of LONGEVITY should be fine. but if you have a bad tuned engine with improper fueling category, then it'll blow.
KAY 3333 said:thnks very much bro for the information.
is it cosworth piston coated??
KAY 3333 said:is it mahle piston good??
by the way this info help bro thanks
ace79 said:Ooohhhhh...Mahle pistons? These high - end pistons ( Mahle and Cosworth etc ) will cost you a lot of moolah, and you have to warm up your car properly ( at least 8 - 10 mins! ) bfr you can drive off. Reason be, these pistons does not seal up properly when cold. Only when it's warm, will these pistons expand to it's actual proper size, and only then you can rev the car off to the moon.
So, think twice bfr going for any forged pistons, especially the high end ones like Mahle and Cosworth.
I believe you're running a B20B bottom end. If you still want to rev your car over 9k RPM, maybe some oversized PCT pistons instead? But to have your B20B rev up to such levels, block bracing, better rods, maybe a stronger crankshaft, and an improved oil pan ( like from Mugen, Spoon, J's Racing etc ) is required. Also a better fueling circuit and maybe at least EManage as well. Don't forget your valvetrain components as well. This will cost you, at the very least, RM 10k.
yaya so any cheaper brand??hattech-v said:mahle piston is mahel.... :D
hope to see the car whn is the next drag??J101 said:mahle came out with one of the top range h22a pistons. yeah they are good and so does the rest of the forged piston families. i thought i saw the mahle piston sticker on one of the brownish drag civic from jb with the wheelie bar. :)
