Greddy Profec electronic boost controller NEW
D`s Garage
7,000 RPM
The new PRofec is compact, powerful and easy to use. The large OLED Display, with the simple two-button / rotary-dial control, make for intuitive operation. An ultra slim controller can display in digital, bar-graph, or graphical modes and can be rotated 180 degree for installation with the included adjustable mount or flush mounted. By separating the display and control unit in the driver’s compartment, from the engine compartment-mounted, waterproof, sensor unit, it makes installation straightforward. Only one thin harness is required to be routed through the firewall. The combination of the new 300kPa (43.5psi) integrated pressure sensor, the more compact solenoid valve and faster ECU processer, provide quicker response and the most stable boost curves yet. The PRofec also maintains popular features like, Lo, Hi, Scramble boost presets, last-boost display, peak-hold recall, warning alert and safety limiter. The next evolution of the GReddy PRofec line of electronic boost controllers is here!
~Easy to use controls~
Simple rotary-dial and dual push-button layout.
~Intuitive Dial Operation~
Unique to this latest generation PRofec is a larger ergonomic rotary-dial control.
~New Compact Solenoid and Improved CPU Control~
~Excellent Visibility with the OLED Display~
OLED (Organic Light-Emitting Diode) display offers excellent visibility at a wider range of angles.
~Slim Design Offers Multipule Mounting Options~
(89mm X 36.5mm - 11mm thick flat-screen)
Interested please contact us @ [email protected]
We are located in Bandar Sunway beside Sunway College.Behind Works Engineering & N1 Racing
Same row with ATS Plus & Trial Performance
D`s Garage
No.37,Jalan PJS 11/9
Bandar Sunway 46150
019-3891881 (MATT)
016-9973300 (DENNY)
:adore:
---------- Post added at 11:03 PM ---------- 6 hour anti-bump limit - Previous post was at 05:39 PM ----------
:adore:
