Gearbox manual 222 vs 312
Ok guys, ive gotten the 312 gearbox from lan eterna for a good price(Full set+ original parts for err RM4.4K), so now my car is in the process for the gearbox transplant. I wanted to ask, what is the best exhaust modification thats needed to be done and also the price for it? I was told that to change my piping to a 2.3 inch direct flow with a 2.5 inch muffler, what do you guys think?
EDIT:
And you guys, your RPM at 3k on 100kmh in the 5th gear? well thats a bit high lol :D, but it still does save more petrol compared to the standard auto gearbox right?
Hi hex999..sorry for disturb..can you srnd me contact lan eterna..im looking for gearbox to..
don't think lan eterna is in the modification business already, he diverted his business into some other field.
The 332 manual? Can fit to a standard V6?
yes able to as 332 is 4wd gbox from 6a12tt. hence u have to lock it to 2wd, has longer ratio too, flywheel is 9"
312 on the other hand is 2wd, no need to lock, but there is a 312 4wd version too.
best for v6 n/a is 222 or 232 manual. shorter ratio. flywheel 8.5"
if 222 or 232 manual used on 6a12tt, the 5th gear syncro will wear out faster, not recommended.
Ohh thought base on previous posting u recommended the 312 the best for a 6a12 2wd (NA)..
For me FC is not an issue. I believe more power- more FC ..:biggrin:
Summary...
222/232 Manual short ratio = best for 6a12 NA 8.5' clutch
312/332 Manual Longer ratio = best for 6a12 TT 9'clutch
Hi guys..i just get another gearbox code 312..but the price is 2.5k..upah pasang add on another 700..the guys said it complete set..so total is 3200..
Question is..it is the price or i got cheated..or maybe the gearbox are diffrent..how i want to know gb are compitable with my 2.0 v6??
312 2wd is the best for 6a12tt.....cos no need to lock the 4wd, but 6a12na also able to use.
---------- Post added at 08:09 AM ---------- 6 hour anti-bump limit - Previous post was at 08:08 AM ----------
its worth it, my time used to be above RM4k.
wahh 3200 good price bro!!!
I cant find less the 4.2k
---------- Post added at 12:12 PM ---------- 6 hour anti-bump limit - Previous post was at 12:03 PM ----------
bro?? have the contact??
Hi guys..i just got another manual gb..the guys want to sell said..this gb from eterna..can anyone verified its suitable with perdanahttps://www.zerotohundred.com/forums/attachments/543100.vB
How do I know if the 312 is 2wd or 4wd? Will I know from the code?
Thanks.
Sent from my MI 3W using Tapatalk
Hi all, which short shifter is suitable for 312 gearbox?
Thanks.
Hi Sifu's, I just got a 312 gbox without a flywheel. My mechanic told me that he will use the 8.5" flywheel from a 222 code gearbox. I am wondering would the 312 gearbox run properly with the 8.5" flywheel? And if its able to run properly, what sort of difference in terms of Acceleration and top speed?
