Garage sale
wkautech
Endless 4 pots Front calipoer and rear Endless disc rotor set for Satria rm6000
Rear anti-roll bar or lower arm for Satria rm1400
Front lower arm for Satria rm250
Zeal high low soft hard adjustable absorber for satria ( for track use ) rm4500
Tanabe high low adjustable suspension kit for Satria rm2000
Tom's TECS ecu for AE101 (for 264 cam use ) rm2100
omori oil cooler set rm900
Greddy oil cooler set rm900
Toda 288 cam 1 pair for 4A-G 20v rm2400
Toda 264in 256ex cam for 4A-G 20v rm2200
Blitz K26 turbine rm1300
Turbonetic high performance turbine for 4G63 rm2400
Cusco Racing clutch kit for 4A-G 20v rm800
Brembo 4 pots caliper with 330 disc rotor for celica zz231 (previously used on demo car ) rm10,000
4A-G 20v C56 gearbox ( herical lsd ) rm800
4A-G 20v blacktop engine rm1000
4A-G 20v silvertop fully balanced race engine rm1500
TRD high low soft hard adjustable suspension kit rm1600
RG high low adjustable suspension kit ( short stroke ) rm1600
toyota levin original tower bar rm40
Blitz K26 turbine with manifold, frontpipe, wastegate, metal gasket, intercooler, trust BOV for 4A-G 20v rm3000
17" BSA 6 spoke sport rim 114.3 4 holes 1 set rm700
17" JRD 5 spoke sport rim 114.3 4 holes 1 set rm600
17" Silverstone slick tyre size 225/17 rm200 per piece (1 set for rm700)
AE101 pillowball upper mount front set rm350
4A-GZE supercharge engine with gearbox (AE101) rm 1200
AE111 4A-G 20v engine head rm400
more stuff for sale...........
plz call 012-213-9861 william for enquiry or ask for discount
pictures are available but better come and see it!!!
My shop address is : No.8, jalan 2/108c, taman sungai besi, 57100 k.l.
i got fren want to find the CAM for his 20v
i want to ask that the TODA 280 cam the standard ECU can support right .... need to change also it's bcoz standard only support up to certain level :) pls advice Mr Sifu
hgahahah
standard ecu cannot stand 288 cam, unless got tuning ecu or at least S-AFC
Originally posted by 4agze@Feb 16 2005, 03:59
no need to change bigger valve springs ah?
bigger valve spring :blink: :ph34r: :ph34r:
Quite interested on the turbo kit.. hahahahaha but must modify alot of things worr...
William, can i run on low boost and stay stock on my internals ?
the cusco clutch kit contains the clutch lining and pressure plate right?
is it much more heavier than the stock?
is this brand new?
thanks.
yo william.
those brembo brakes looks very tempting
is it the one you showed me before?
4A-G 20v silvertop fully balanced race engine <---- what's been done to the engine? Wiring?
haiyaaa...so came so late...same price with my full overhauled engine... :((
saw the endless 4-pot.
so damn chun :P
but not enough money to buy.
Additional parts for sale
levin from disc rotor and caliper ( recommend for upgrading original SEG corolla 1.6 ) rm200 per set
levin rear disc rm280 per set
Greddy Oil catch tank ( NEW ) rm 380
5 zigen oil cap rm120
TOM's air ramp for levin AE111 coupe rm 600
Recaro SP-G Racer rm2700
4A-G 20v AE111 flywheel rm200
TRD oil pan ( for dry sump ) rm 2500
AE101 , AE111 throttle body from rm250-350
Trial Tuning Adjustable cam pulley, Reshim, cam setting for 4A-G 20v rm 950
AE101, AE111 piston (used) rm150
OER VVT controler rm450
AE101, AE111 ported, reshim head rm 800
still got a lot to go....................
how's da condition???
I'M VERY INTRESTED IN IT
slurpzzz
:rolleyes: :rolleyes: :rolleyes: :rolleyes:
