Flywheel Modification
vtec_mivec
Wanted to modify/lighten your flywheel for more respond and minimize cost with great quality???without any power lost when your car face a hill road???
We provide everything for what u need in flywheel modification with the lowest cost.....
The pakage option as below:-
Option 1(Normal/Daily Driven car)
Original Exedy Clutch Set(complete set with clutch cover and clutch bearing)+Flywheel Modification+Flywheel Oil Seal(Japan)+Castrol Gear oil+Service Charge
Option 2(If Your Clutch Plate still new)
Flywheel Modification+Clutch Bearing+Flywheel Oil Seal(Japan)+Castrol Gear oil+service charge
Option 3(Race Clutch Set)
Original Exedy Racing Clutch Set(3 puck)(complete set with clutch cover and clutch bearing)+Flywheel Modification+Flywheel Oil Seal(Japan)+Castrol Gear oil+Service Charge
All specified parts must be changed according to the option in order to get the full warranty.
OF COURSE THERE ARE WARRANTY FOR ALL SERVICES THAT DONE IN THE FIRST PHASE AUTO WORK
benefits:-
1.Give the engine more respond to the throtel opening
2.Increase horsepower due to the ligthen flywheel
3.Reliable due to the balance done to the flywheel
4.No hassle even the car climbing the hill road compare to the normal
ligthen flywheel which is done wrongly will cause the car feel heavy.
For the price please PM or BETTER call me at 019-5433744(Jasry) no sms will be entertained.
Please state your engine/gearbox for me to give the quotation about the price.
Our workshop is in:-
First Phase Auto Work,
69,Block J,
Jalan 3,
Batu Caves Centre Point,
Batu Caves.
price:
Flywheel Modification+Flywheel Oil Seal(Japan)+Castrol Gear oil+service charge
Benefits:-
69,Block J,
Jalan 3,
PM Me best price for Honda Civic D16, single cam non vtec.
Any warranty? i am using original clutch, PM me Option 1 and Option 2 best price.
Thanks
mine is wira 1.5 M. PLease PM me the best price for the option 1. Is it can feel a lot of the hp/torque increase
of course u can feel the different....
how much for the 20v bt flywheel modification, for drifting. how much weight for the flywheel after modification
maximum reduction is depending on the type of engine...NA/turbo...and purpose of the mod as u said for drifting is different.....for drag is different and for daily driven is diff. so basically it depend on the purpose of the mod.
ok, you've listed the benefits....any disadvantages?? as a potential customer, i feel i have the right to know...
as u can read my benefits....u also can read about the disadvantage right???in case u dont.....see benefits number 4....it will occur if u reduce the flywheel too much...other than that...it also can cause the lost of the top speed due to the reducing too much weight from the flywheel...for us, we know how much to reduce the flywheel without effecting any of of that.
pm me the price for option 1...for satria gti
pls pm me too...option 1 for Satria Gti also.clutch worn out so time to change already.
