I had this problem once, same code as you. It shows air intake pressure (which were removed long long time ago) .
Check light pop up and won't turn off unless restart the car. Send to mech, change the MAP sensor instead and settle.
Not sure this helps.
oic ...yaya ...the check light pop up and won't turn off unless restart the car .......same with u ....
any sign beside that ?? ....cuz my car got a sign of while full throttle of the pable .....the engine will " sepu " while at RPM range 2500 - on ward ..
if just press the pable softly....it will be ok a bit ........
km chew ...ur car got this sign last time ???
TT time!!:beerglass:
