Error code
antuquboq
Cheras
juz install vafc1, now my ecu throwing CEL code 22 VTEC oil pressure switch, whats that mean? anybody here got this prob after install vafc??
code 22 - vtec oil pressure switch -
defective circuit or unplugged / defective oil pressure switch ..
i also got this prob..why arr? wiring problem kaa? :D
which means .. check the plug/socket .. mebe one of wires tercabut or plug/socket dah tercabut or broken ..
http://img.photobucket.com/albums/v230/antuquboq/76f02d11copy.gif
wandi.. borrow ur pic :P
sham.. situ ke sensor dia? kat arrow merah.. kaler ijau
Originally posted by antuquboq@Mar 2 2005, 11:25
xtau ah.. check ok je.. xde tercabut.. try topup minyak itam dlu.. :huh:
try to open the socket .. from the outside mebe looks okay, mebe some cracks kaa .. kasi bersihkan ..
hizal member aku pun kena problem cam kau. check engine light nyala code 22. the solution - take out the pressure swith plug n replace with a new one (alternatively take out the old plug n clean it..mungkin sumbat..)
after he changed to a new one the problem is gone bebeh
Originally posted by lightningfield@Mar 2 2005, 11:48
cabut spool valve n take out the pressure switch plug. alang2 service terus spool valve tu. ok cara?
godd idea .. but how haa?? can cabut just like that kaa ?? ..
unplug all the switches..then unscrew a few screws n take off the spool valve from the head. then u may unscrew the pressure switch plug with spanar 10 (i think). or if u r good enuff..no need to take off the spool valve.. just take out the plug - hehhe. cun maa..
wandi pinjam gambar.
spool valve dlm bulatan tu jugak. yg silinder seketol tu. yg selalu leaking tu.. dkt cable plug..
