i have a problem with my engine. bad idle. check engine light blinking shows code 4 2. refer to the gti diagnostic chart, it means crank angle sensor. what should i do. anybody can help me?
problem fixed. found no.1 spark plug melt. i replace the spark plug and the check engine light clear. it happened when in a hi rev. i don't know why the spark plug melt. it happened to me 2 times. only no.1 spark plug :hmmmm:
If I'm correct, your head gasket should be faulty this moment ...... You can try to send your car to workshop and have engine compression check see all 4 cylinders have the same compression reading.
Hi bro,i need some help on how to install the latest model of Vios's cd player in my Kelisa?
the player come wit:-
Power socket with:
1red wire
1white wire
1black wire
1yellow wire
