ecutek
Hi bonet, call links power Mr kee 012-3922022 to find out, for i know it goes for evo 4-8 and subaru sti only. tell him (kolo chong) reccoment 1.
hahah of course.will put at evo 6.5 tme.shariman(red tme at links) recomended it to me.maybe u know this man.btw do anyone have experiance using this ecu??
ECUtek doesnt replace your stock ECU. Instead, you 'reflash' your stock ECU so that you can install your own maps, with your own parameters for boost, fueling and timing. It is safe to the extent that it maintains the stock knock detection capabilities and stock idling characteristics. As long as you have a good tuner who knows what he's doing, you should be happy with it. Good luck.
EcuTek is not a piggyback system, neither is it a standalone ECU. There is no hardware required to be installed in your car.
EcuTek is basically software that can read and modify your standard ECU's parameters, such as boost profile, boost limit, rev limit, fuelling & ignition timing. The tuner will use a laptop to connect to your ECU through the OBDII plug, and then recalibrate these parameters to suit your car and its mods.
Dont look down on it because it is just software - the stock EVO ECU is already very advanced, and can be recalibrated to produce very substantial gains in hp and torque. Make sure that you do your engine mods first (intake, exhaust, turbo, injectors, etc.) before you do the EcuTek tune, so that you get the most out of it.
EcuTek supports EVO 5 onwards, as well as all turbocharged Subarus from year 2000 onwards.
One useful tip - whoever tunes your car, make sure you ask him to give you a dyno reading before and after the tune, so that you can have a comparison on paper.
ooic.tq so much my friend.u kind a familliar wif this item.mm just software already price 4k+ hahaha
