Bless up. I have a problem with my 1998 Daihatsu Move L601. I changed my car from Automatic to Gearbox, after that convertion the car cranks but no spark from the ingition coil.
I had ran a series test on the distributor pickup coil (249ohms, .247ACVolts), test the ignition coil(primary circuit(.9ohms) Secondary Circuit(13kOhms))and dont no how test to the ECU Transistor.
I carried the ECU to an electrical technician and he told me a IC was bad, so i had a identical ECU and replace the IC.
The car also is displaying a diagnostic code (51(Switch Signal)) found out the TPS sensor is not working.
Could someone tell me what i could do to get the car to start, and if i could get a ignition moulde to go around the ECU?
Thank you.
Thank you.
i even cant saw this car in Auto saloon 2009...
