EASYCAR 2-Way Alarm EW402AS
DBL-Vie Auto
http://sitebuilder.yola.com/sites/S3/D838/D16e/D360/De7a/U8a4986cb22a737a50122a7e063e61838/8a49866b22a7378d0122a7e5724d0936/resources/Ew402ModifiedDonePic1.jpg?timestamp=1250105933395
Remote Control Design
Duplexed communication system core's controller. Button dipositions and antenna share are designed and developed in the human body technological way for accurate transmission/reception of radio wave, complying with national radio wave.
Remote Control Display
Soon confirmation of car informations with icons about (20 sorts). Night radiation function by high-intensity back light, Car checking for 24hours and alarm ( Vibrations ) promise your safe car life.
Colorful Remote Design
This small and handy design comes in three colors. You can choose either RED, BLUE or METALLIC SILVER. Each of our package comes with a luxury genuine Leather Case for you to protect your remote control.
http://sitebuilder.yola.com/sites/S3/D838/D16e/D360/De7a/U8a4986cb22a737a50122a7e063e61838/8a49866b22a7378d0122a7e5724d0936/resources/2009_2b%20modified.jpg?timestamp=1250281720126
[EW402AS]
2-Way Communication
Modulation : FM(FSK)
Carrier Frequency : 433.92MHz
  • Alarm
  • Alternator Engine Sensing
  • Anti-Grinding
  • Anti-Jacking
  • Auto-Arming
  • Auto Start
  • Aux Outputs
  • Diesel Powered Vehicle
  • Driving Door Lock
  • Dual Shock Sensor
  • Easy Door Lock By password
  • Engine Running Time
  • Extra Sensor Input
  • Hood Trigger Input
  • Keyless Entry
  • Long Pulse Of Lock/Unlock
  • Manual Transmission
  • Noise Engine Sensing
  • Onboard Relay Door Lock
  • Parking Brake Input
  • Parking Lights Input
  • Parking Lights
  • Passive Arming/Locking
  • Propane Gas Powered Vehicle
  • Remote Paging
  • Remote Vibration
  • Shock By-Pass
  • Signal Lights
  • Siren (6 tones)
  • Starter Kill
  • Status Output
  • Time Clock
  • Timer Start (24H/3H)
  • Time To Rearming
  • Trunk Sensor
  • Turbo Mode
  • Valet By Key/Remote
  • Owner Call Mode
Package list
  • [*]1x LCD 2way remote
    [*]1x M5000 main controller
    [*]1x Antenna module
    [*]1x 1 way remote
    [*]1x Dual shock sensor
    [*]1x Siren
    [*]1x LED Ass'y
    [*]1x Knock sensor
    [*]1x Easy door lock
    [*]1x Tempearture sensor
    [*]1x Leather case
    [*]1x Wire hardness kit
    [*]1x Hood switch
    [*]1x User guide
    [*]1x Installation guide
    [*]1x window warning sticker
    [*]1x Full colored gift box
YouTube - EW402AS Remote
EASY DOOR LOCK
http://sitebuilder.yola.com/sites/S3/D838/D16e/D360/De7a/U8a4986cb22a737a50122a7e063e61838/8a49866b22a7378d0122a7e5724d0936/resources/KnockthedoorBlackModifiedDonePic1.jpg?timestamp=1251168887898
Remarkable New Function Installed!!!
Just knock 4 Digits pre-installed password, you can arm(Door Close)/disarm (Door Open) the car security system without remote controller. Sensor part built-in 10 LEDs can display various status depend on its function.
Auto Start
Press button ll for 2 seconds, [start] appears, then remote chirps and parking light flash once each. If it fails, the system tries auto start maximum 3 times automatically.
The engine running time will run 15 minutes basically. You can change it to 25 minutes by optional setting. You can press button ll for 2 seconds to turn it off.
Trunk Open
Press button lll for 2 seconds to unlock the doors and open thr trunk with twice chirps and parking lights flashes.
Query Function
Query function allows you to check the status of your car by pressing button lV for 0.5 second. The icon and the chirp sounds show you the status. If you are within trnsmitting distance to receive the signal for shock, theft and easy call, you will receive the responses like chart.
*If the transmitting is impossible, ex~status of your vehicle will be displayed on OLED.
Panic Mode
In this case, your vehicle will lock the doors if unlocked already and the siren will activate and the parking lights will flash for 1 and half minute.
This function is used for warning under emergency when you feel feel your personal danger and informing your situation.
Real Time Remote Paging Function
Whenever one of Owner call, Theft report and Shock sensing report is triggered, it is reported to the remote with beeps and flashing icon on LCD.
In particular, Theft is reported with continuous beeps in consideration that you didn't hear the beeps. In this case, vibration is set, blue LED on remote blinks rapidly.
Shock Sensing Report
This function reports to your remote any shocks at your vehicle in arming mode. When your vehicle is shocked, your remote sounds warning continuously.
Theft Report
Our system recognizes it as Theft and avtivates Alarm function when doors open by force or with the key in arming mode.
Auxiliary Output (optional)
This mode is used to control (on/off) one of the various functions such as Convertible car, Sunroof, Car Audio, Window Remote Power etc.
Knock Sensor (option setting)
If you knock just twice during Arming remote bells. This function can not be used Key On and Ignition On. And also, thisplays as LED role for Arming display.
Owner Call
This mode allows people to call u by knocking the knock sensor 2 times on the front window of the vehicle. You can recognize this call through the icon on the remote TFT LCD.
Valet Function
Valet mode is useful when loaning your vehicle or having it served (example: car wash, parking lot and auto repair shop).
Passive Mode
The door are locked automatically in 30 seconds after all the door are closed and engine is off.
Driving Door Lock (ignition lock)
This function enables your vehicle to automatically lock the door in 30 seconds after starting.
On the contrary, the vehicle automatically unlock the doors when you finish the starting.
Shock Sensing
*Example* It is useful when you or your baby sleep in the vehicle, or your pet stays in the vehicle.
Timer Start
The vehicle will automatically start at reserved time every 24(3) hours.
Turbo
Under this mode, engine keeps running for 30 seconds(it can be changed to 2 minutes by optional setting) after key has been taken from ignition.
This mode is useful for turbo vehicle that need to be cooled down after long drive.
*Original Price RM 738 With Installation Including.
Feel free to visit our website www.dbl-vie.yolasite.com[/B] and do not hesitate to email us [email protected] if you have any further enquiries.
DBL VIE AUTO TRADING
Call or SMS +6018-9508211/+6018-9519992
YouTube - Easy Door Lock
YouTube - Smart Door
YouTube - Auto Side Mirror Foldoing YouTube - iran TV ads
http://i6.tagstat.com/image04/8/2f6d/0029051u2ZJ.jpg
http://i5.tagstat.com/image04/8/2f6d/0028051u2ZJ.jpg
http://i0.tagstat.com/image03/8/2f6d/0027051u2ZJ.jpg
http://i5.tagstat.com/image04/8/2f6d/002a051u2ZJ.jpg
*All materials, man power and its cutting edge technology are truely from Korea.
*No Modifications as all Accessories in the package set are manufactured and genuine from Korea.
*Our Products are provided with 2 years warranty.
